MailScanner showing 0 proc(s)
Hi, I’m using ubuntu 20.04 and recently install a fresh cyberpanel copy, I have installed spamassassin and mailscanner from Cyberpanel admin area, the problem is when login to the admin panel located in serverip:8090/mailwatch/mailscanner/status.php
MailScanner show 0 proc(s).
I have also tested with CentOS 7 and get the same result.
Anyone know how solve this?
CyberPanel dev team is working and checking this side by side and will let you know soon about this
Did we ever get anywhere with this as I’ve just discovered I’m having the same issue?
i’ve seen this Issue: MailWatch unable to detect that MailScanner is running or tally the children processes · Issue #1254 · mailwatch/MailWatch · GitHub where because of hidepid (a security feature of cyberpanel) we get the error that mailscanner and postfix are not running (even though it is)
