Majority of problems get solved with just updating cyberpanel.
I continuously have this problem every time I update Cyberpanel and this is what works for me (Ubuntu 20.04).
- On your server, check your directory structure and verify that ‘/usr/libexec/dovecot/deliver’ exists.
- If it does not, the correct location will probably be ‘/usr/lib/dovecot/deliver’. Note ‘lib’ instead of ‘libexec’
- Edit ‘/etc/postfix/master.cf’ and modify the line at the bottom from:
dovecot unix - n n - - pipe
flags=DRhu user=vmail:vmail argv=/usr/libexec/dovecot/deliver -f ${sender} -d ${recipient}
to (changing ‘libexec’ to ‘lib’)
flags=DRhu user=vmail:vmail argv=/usr/lib/dovecot/deliver -f ${sender} -d ${recipient}t}
Then restart dovecot, postfix and check the status:
$ sudo service dovecot restart && service postfix restart;
$ sudo service dovecot status && service postfix status;
Once I do this, I can now receive (and send) emails again.
