Hello.
Is this how it should be?
In the console, I previously executed only one command:
systemctl restart lscpd
Hello.
let me guess… you are using newest version ?
Latest CyberPanel.
CentOS 7.
actually this is happen to me …too…
after upgrade to new version
just hoping developer will takecare of this ASAP
Thanks for the explanation.
im not explain anything ![]()
For me, you explained that this is the situation with the engine now.
So I didn’t break anything ![]()
But the situation is not critical terrible.
Because the CPU is used at 100% only when the admin is sitting on the panel home page.
If you exit the panel, the CPU stops loading.
i hope this is not because what we did …
i dont have a backup ![]()
My server started yesterday.
It has a clean version of CyberPanel installed on it ![]()
great … dont forget to take snapshot everytime you want to upgrade cyberpanel…
sometimes we have fix on this bug… but with that… old bug and/or new bug just revealed
I have the same issue, wonder if I an manually kill that process?
Friend, we are in the same situation, I still don’t know what it will be, and no one answers
Cyberpanel is already giving me a bad feeling
