barlas
February 5, 2019, 12:00pm
1
hi,
I am using a 4 core Intel(R) Xeon(R), 8gb ram with a vps.
I did panel installation smoothly… but when I actived lscache and run CSS Minify (CSS Combine, JS Minify, CSS HTTP/2 Push can also be…) the server is being locked, cpu load reaches the %100 values.
Is there a setting this except for the default setting ?
qtwrk
February 5, 2019, 7:57pm
2
Please try enable them one by one , to see which one is creating the load.
barlas
February 5, 2019, 8:32pm
3
I’m starting to try with css and after html minify, gets stuck cpu load both of them.
I did not look at the other. Is there a setting I missed?
qtwrk
February 6, 2019, 9:05am
4
if you only enable css , does it overload ?
barlas
February 6, 2019, 12:52pm
5
Yes, I try to enable only CSS Minify, cpu load %100 again. And then ı am going to restart openlitespeed. it comes back.
qtwrk
February 7, 2019, 10:34am
6
if you create another new WP with LSCWP, and enable CSS minify will it overload ?
if it doesn’t , try disable all other plugins in your site and try CSS minify see if it overloads.
barlas
February 7, 2019, 11:37am
7
ı was using before wp-fastest cache premium. I was not having trouble.
Problem can be around; htaccess permission, openlitespeed settings or php adjustment ?
All settings are default.
