Hello everyone,
Someone knows how to enable lscache crawler for prestashop under cyberpanel with litespeed enterprise?
I’m getting this message from CLI:
Server crawler engine not enabled…
… Stop crawling…
I’m lost with the docs from litespeed’s wiki.
Admin | LSCache for WordPress | LiteSpeed Documentation
Hello
Since CyberPanel Ent use Apache backed configuration files you can add the following in your configuration file
CacheEngine on crawler
The file is located at /usr/local/lsws/conf/httpd.conf
. If you want you can create a seprate crawler.conf
in /usr/local/lsws/conf
with above contents and include it in /usr/local/lsws/conf/httpd.conf
Hello
You are awesome @CyberPanel it work like a charm! Thank you so much! <3
Out of curiosity, how would I enable the crawler in OpenLiteSpeed?
Actually, to circle back since I have since found the answer prior to your reply, I found out from here that the crawler is already enabled by default in OLS. That used to not be the case but the crawler is part of the feature set as of the date of the post in the link:
