Login to phpmyadmin without autologin
I want to enter phpmyadmin without autologin. To be able to enter with the root account. But autologin does not allow me. I want to change the sql-mode setting.
You can try this…
cd /usr/local/CyberCP/public/phpmyadmin
mv config.inc.php config.inc.php.old
mv config.sample.inc.php config.inc.php
Is this working? If I want a direct PHPMyAdmin feature?
Ideally, both should work but direct login is more important.
The auto login to phpmyadmin is working with cyberpanel at the begining.
But I have a question that , I change the default root password of mariadb for security reason.
I also change the database root password as below.
Sudo vi /usr/local/CyberCP/CyberCP/settings.py
sudo vi /home/cyberpanel/.my.cnf
sudo vi /etc/cyberpanel/mysqlPassword
Most function work correctly after I change these file setting. But the phpmyadmin autologin function
has trouble with it. if I click the button on the cyberpanel to access the phpmyadmin, it will show a blank page.
I can temporary login to phpmyadmin by doing this:
I know that it just make the default config.sample.inc.php to be work , But the problem is that
there is no more “Autologin” function for PHPmyadmin anymore if I replace the config.inc.php.
So, any body know how to solute the problem properly ? Just want the Autologin function back after
changing the database root password every time.
Please do not create duplicated queries marking yourself in red flag for spam. You have already opened a new thread mentioning this same issue and I have replied to that.
