Hello to the community !
I am a novice and just started playing with CyberPanel. I have installed it on Ubuntu 22.04 LTS instance and just started playing around.
I am experiencing an issue with logging into OLS. I am visiting open litespeed portal and using the admin credentials to access the webpage panel, however I am getting the error ‘invalid credentials’ on the front end. Looking into it in the debug console, the server seems to be responding a successful response (http code 200).
Looking at the logs, I noticed that a potential issue could be associated with WatchDog. I could not post the information here due to forum’s policy for 2 links.
2023-05-22 12:22:04.259361 [NOTICE] [15825] [{{myip}}:49744:HTTP2-7#_AdminVHost] [STDERR] [WebAdmin Console] Failed Login Attempt - username:admin ip:{{myip}} url:
2023-05-22 12:22:35.062926 [NOTICE] [15825] sendKillCmdToWatchdog: 'extappkill:16099:-3:0'.
2023-05-22 12:22:35.601274 [NOTICE] [15823] Cmd from child: [extappkill:16099:-3:0]
2023-05-22 12:22:35.601368 [INFO] [15823] Failed to get process [16099] start time, not running, skip killing.
A last note is that the SSL is not properly installed -I don’t know why- on the LiteSpeed portal. Visiting my domain on https, I am getting an encrypted connection with the correct SSL issued from the CyberPanel, however when visiting mydomain on https and port 7080, I am getting an insecure page, which I allow. The SSL associated is a self-signed www.example.com certificate.
Any ideas ?
