Letsencrypt giving "Self Signed SSL" every time, Please help me, I am frustrated
Every time I apply for letsencrypt SSL by Cyberpanel, it shows success message, but when I check the issued SSL, I always see that it Self a Signed SSL.
[currently, I am using Cloudflare SSL, but I do not want to use cloud Cloudflare SSL, because I need letsencrypt mail server SSL.]
managed by cloudflare
is this domain is your mail server ?
then you should to grayed out the mail.inbangla.net direct to cyberpanel server
then create mailhost ssl directly
Yes
then you should to grayed out the mail.inbangla.net direct to cyberpanel server then create mailhost ssl directly
I am Sorry, I do not understand, can you explain more In detail
Thanks
Now, I removed inbangla.net and mail.inbangla.net from cloudflare. now it has only Letsencrypt issued self signed ssl through cyber panel.
Also I tried to install SSl using Terminal, but got error:-
root@server1:~# certbot certonly --webroot -d mail.inbangla.net
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator webroot, Installer None
Obtaining a new certificate
An unexpected error occurred:
There were too many requests of a given type :: Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: mail.inbangla.net: see Rate Limits - Let's Encrypt
Please see the logfiles in /var/log/letsencrypt for more details.
(what I understand that, letsencrypt issued Self Singed SSl 5 time, thats why I got Limit, I can apply again for SSL after a Week, and there is no guarantee I will get real Mail server SSl or Self Signed!!!)
you should disable cf proxied the IN A of your mail domain
(https://domainname.tld:8090/manageSSL/sslForMailServer)
LE Cert limit 5x issue every 1 week
you should wait next wednesday to re-issue
ok, I am waiting.
but question in my mind, why cyberpanel + letsencrypt issued Self Signed SSL again and again,
and after limit reistriction is removed in future, it can give me Self Signed SSL again,
How can I get rid of from this letsencrypt issued Self Signed SSL!
and how can I get a real letsencrypt Mail server SSL
Thank you very much MyIDKaTePe for helping me.
ok,
As you said, I disabled cf proxy in A of my mail domain.
i will guide you later after limited issue are end…
just remind me to guide you if not wednesday then you should wait 1 week
i still have no accurate info about “limitation per week” for LE cert
that mean every wednesday
or 1 week after limit reach…
but just PM/Inbox me to remind me… i will help you
but not at PM, i will help at public thread so if it solved. other ppl will learn about same thing
I tried today to install a Mail Server SSL
TODAY SHOWS UP A DIFFERENT ERROR:
Cannot issue SSL. Error message: [Fri 08 Apr 2022 03:19:55 PM UTC] Registering account: https://acme.zerossl.com/v2/DV90 [Fri 08 Apr 2022 03:20:00 PM UTC] Already registered [Fri 08 Apr 2022 03:20:00 PM UTC] ACCOUNT_THUMBPRINT=‘xzMP82VyoCUtdYq-zeUBS3L2JeB-9l9F8RPYXocmLcw’ [Fri 08 Apr 2022 03:20:09 PM UTC] www.mail.inbangla.net:Verify error:DNS problem: NXDOMAIN looking up A for www.mail.inbangla.net - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for www.mail.inbangla.net - check that a DNS record exists for this domain [Fri 08 Apr 2022 03:20:09 PM UTC] Please add ‘–debug’ or ‘–log’ to check more details. [Fri 08 Apr 2022 03:20:09 PM UTC] See: How to debug acme.sh · acmesh-official/acme.sh Wiki · GitHub 0,[Errno 2] No such file or directory: ‘/etc/dovecot/dovecot.conf’
What should I do? install dovecot?
After I installed Dovecot and apply for mail server SSL and got mail server SSL successfully.
