my main issue is i ca’t access rain loop i keep getting ×Authentication failed
below is from the email log
Jan 16 09:10:24 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: imap-login: Warning: Auth process not responding, delayed sending initial response (greeting): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<mm3x2wC5zo9/AAAB>
Jan 16 09:10:44 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: imap-login: Error: auth-client: conn unix:login (pid=36082,uid=0): Timeout waiting for handshake from auth server. my pid=37883, input bytes=0
Jan 16 09:10:44 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: imap-login: Disconnected: Auth process broken (disconnected before auth was ready, waited 30 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<mm3x2wC5zo9/AAAB>
Jan 16 09:11:02 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: auth: Fatal: sql: Unknown database driver ‘mysql’
Jan 16 09:11:02 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: master: Error: service(auth): command startup failed, throttling for 60.000 secs
Jan 16 09:13:06 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix[37943]: Postfix is running with backwards-compatible default settings
Jan 16 09:13:06 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix[37943]: See Postfix Backwards-Compatibility Safety Net for details
Jan 16 09:13:06 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix[37943]: To disable backwards compatibility use “postconf compatibility_level=2” and “postfix reload”
Jan 16 09:13:07 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix/postfix-script[37949]: stopping the Postfix mail system
Jan 16 09:13:07 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix/master[36073]: terminating on signal 15
Jan 16 09:13:07 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix[37968]: Postfix is running with backwards-compatible default settings
Jan 16 09:13:07 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix[37968]: See Postfix Backwards-Compatibility Safety Net for details
Jan 16 09:13:07 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix[37968]: To disable backwards compatibility use “postconf compatibility_level=2” and “postfix reload”
Jan 16 09:13:07 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix/postfix-script[38033]: warning: symlink leaves directory: /etc/postfix/./key.pem
Jan 16 09:13:07 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix/postfix-script[38036]: warning: symlink leaves directory: /etc/postfix/./cert.pem
Jan 16 09:13:07 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix/postfix-script[38039]: warning: symlink leaves directory: /etc/postfix/./makedefs.out
Jan 16 09:13:07 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix/postfix-script[38199]: warning: /var/spool/postfix/etc/hosts and /etc/hosts differ
Jan 16 09:13:07 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix/postfix-script[38217]: starting the Postfix mail system
Jan 16 09:13:07 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix/master[38219]: daemon started – version 3.4.13, configuration /etc/postfix
Jan 16 09:13:54 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: auth: Fatal: sql: Unknown database driver ‘mysql’
Jan 16 09:13:54 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: master: Error: service(auth): command startup failed, throttling for 60.000 secs
Jan 16 09:13:54 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: imap-login: Disconnected: Auth process broken (disconnected before auth was ready, waited 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<jbtw6AC50o9/AAAB>
Jan 16 09:15:05 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix[38280]: Postfix is running with backwards-compatible default settings
Jan 16 09:15:05 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix[38280]: See Postfix Backwards-Compatibility Safety Net for details
Jan 16 09:15:05 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix[38280]: To disable backwards compatibility use “postconf compatibility_level=2” and “postfix reload”
Jan 16 09:15:05 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix/postfix-script[38286]: stopping the Postfix mail system
Jan 16 09:15:05 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix/master[38219]: terminating on signal 15
Jan 16 09:15:05 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix[38314]: Postfix is running with backwards-compatible default settings
Jan 16 09:15:05 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix[38314]: See Postfix Backwards-Compatibility Safety Net for details
Jan 16 09:15:05 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix[38314]: To disable backwards compatibility use “postconf compatibility_level=2” and “postfix reload”
Jan 16 09:15:06 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix/postfix-script[38377]: warning: symlink leaves directory: /etc/postfix/./key.pem
Jan 16 09:15:06 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix/postfix-script[38380]: warning: symlink leaves directory: /etc/postfix/./cert.pem
Jan 16 09:15:06 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix/postfix-script[38383]: warning: symlink leaves directory: /etc/postfix/./makedefs.out
Jan 16 09:15:06 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix/postfix-script[38543]: warning: /var/spool/postfix/etc/hosts and /etc/hosts differ
Jan 16 09:15:06 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix/postfix-script[38561]: starting the Postfix mail system
Jan 16 09:15:06 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 postfix/master[38563]: daemon started – version 3.4.13, configuration /etc/postfix
Jan 16 09:15:14 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: master: Warning: Killed with signal 15 (by pid=38573 uid=0 code=kill)
Jan 16 09:15:15 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: master: Dovecot v2.3.13 (89f716dc2) starting up for imap, pop3 (core dumps disabled)
Jan 16 09:15:19 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: auth: Fatal: sql: Unknown database driver ‘mysql’
Jan 16 09:15:19 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: master: Error: service(auth): command startup failed, throttling for 2.000 secs
Jan 16 09:15:19 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: imap-login: Disconnected: Auth process broken (disconnected before auth was ready, waited 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<Qp+J7QC51I9/AAAB>
Jan 16 09:15:31 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: auth: Fatal: sql: Unknown database driver ‘mysql’
Jan 16 09:15:31 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: master: Error: service(auth): command startup failed, throttling for 4.000 secs
Jan 16 09:15:31 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: imap-login: Disconnected: Auth process broken (disconnected before auth was ready, waited 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<suQz7gC51o9/AAAB>
Jan 16 09:16:38 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: auth: Fatal: sql: Unknown database driver ‘mysql’
Jan 16 09:16:38 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: master: Error: service(auth): command startup failed, throttling for 8.000 secs
Jan 16 09:16:38 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: imap-login: Disconnected: Auth process broken (disconnected before auth was ready, waited 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<taQ58gC52I9/AAAB>
Jan 16 09:16:49 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: auth: Fatal: sql: Unknown database driver ‘mysql’
Jan 16 09:16:49 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: master: Error: service(auth): command startup failed, throttling for 16.000 secs
Jan 16 09:16:49 cyberpanel-ubuntu-s-4vcpu-8gb-lon1-02 dovecot: imap-login: Disconnected: Auth process broken (disconnected before auth was ready, waited 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, secured, session=<XHLf8gC52o9/AAAB>"
