I’m trying to issue SSL but it’s self-signing again and again.
I tried all below steps:
1:
wget -O - https://get.acme.sh | sh
successful run but nothing happened.
2: tried debugging with command line
/root/.acme.sh/acme.sh --issue -d <YOUR_DOMAIN> -d www.<YOUR_DOMAIN> --cert-file /etc/letsencrypt/live/<YOUR_DOMAIN>/cert.pem --key-file /etc/letsencrypt/live/<YOUR_DOMAIN>/privkey.pem --fullchain-file /etc/letsencrypt/live/<YOUR_DOMAIN>/fullchain.pem -w /home/<YOUR_DOMAIN>/public_html --force --debug
Cyberpanel main log file:
[06.26.2021_16-32-18] /root/.acme.sh/acme.sh --issue -d digiqal.us -d www.digiqal.us --cert-file /etc/letsencrypt/live/digiqal.us/cert.pem --key-file /etc/letsencrypt/live/digiqal.us/privkey.pem --fullchain-file /etc/letsencrypt/live/digiqal.us/fullchain.pem -w /home/digiqal.us/public_html --force
[06.26.2021_16-32-19] Failed to obtain SSL for: digiqal.us and: www.digiqal.us
[06.26.2021_16-32-19] Trying to obtain SSL for: digiqal.us
[06.26.2021_16-32-21] Failed to obtain SSL, issuing self-signed SSL for: digiqal.us
[06.26.2021_16-32-22] Self signed SSL issued for digiqal.us .
[06.26.2021_16-48-45] Trying to obtain SSL for: digiqal.us and: www.digiqal.us
[06.26.2021_16-48-45] /root/.acme.sh/acme.sh --issue -d digiqal.us -d www.digiqal.us --cert-file /etc/letsencrypt/live/digiqal.us/cert.pem --key-file /etc/letsencrypt/live/digiqal.us/privkey.pem --fullchain-file /etc/letsencrypt/live/digiqal.us/fullchain.pem -w /home/digiqal.us/public_html --force
[06.26.2021_16-48-47] Failed to obtain SSL for: digiqal.us and: www.digiqal.us
[06.26.2021_16-48-47] Trying to obtain SSL for: digiqal.us
[06.26.2021_16-48-48] Failed to obtain SSL, issuing self-signed SSL for: digiqal.us
[06.26.2021_16-48-49] Self signed SSL issued for digiqal.us .
[06.26.2021_16-54-22] Trying to obtain SSL for: digiqal.us and: www.digiqal.us
[06.26.2021_16-54-22] /root/.acme.sh/acme.sh --issue -d digiqal.us -d www.digiqal.us --cert-file /etc/letsencrypt/live/digiqal.us/cert.pem --key-file /etc/letsencrypt/live/digiqal.us/privkey.pem --fullchain-file /etc/letsencrypt/live/digiqal.us/fullchain.pem -w /home/digiqal.us/public_html --force
[06.26.2021_16-54-24] Failed to obtain SSL for: digiqal.us and: www.digiqal.us
[06.26.2021_16-54-24] Trying to obtain SSL for: digiqal.us
[06.26.2021_16-54-25] Failed to obtain SSL, issuing self-signed SSL for: digiqal.us
[06.26.2021_16-54-26] Self signed SSL issued for digiqal.us .
Please help
I’m facing this issue in multiple cyber panel accounts
Hello mates,
If you’re facing the same issue
just try below steps:
Open terminal login to root
Run command
sh <(curl https://raw.githubusercontent.com/usmannasir/cyberpanel/stable/preUpgrade.sh || wget -O - https://raw.githubusercontent.com/usmannasir/cyberpanel/stable/preUpgrade.sh )
after successful upgradation.
Login to cyber panel
and reissue SSL
Thanks,
Team DigiQAL Technologies
dampel
June 28, 2021, 5:40pm
3
The panel install certificates for all domains automatically, even if you don’t need it.
This command install certificates for all domains
0 2 * * * /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/renew.py >/dev/null 2>&1
I think it’s a bug.
It’s related?
anisur
June 29, 2021, 6:22am
4
Type your comment> @sandeepdigiqal said:
Hello mates,
Run command
and reissue SSL
Thanks,
thanks my problem fixed , after doing this .
I am getting same issue, unable to get mailserver ssl certificate, hostname and manage ssl is working fine.
I am also having the same problem. In my case only the mail server SSL certificate is working. And the hostname and the main SSL is self signed SSL.
[07.04.2021_10-49-37] /root/.acme.sh/acme.sh --issue -d mail.pixll.dev -d www.mail.pixll.dev --cert-file /etc/letsencrypt/live/mail.pixll.dev/cert.pem --key-file /etc/letsencrypt/live/mail.pixll.dev/privkey.pem --fullchain-file /etc/letsencrypt/live/mail.pixll.dev/fullchain.pem -w /home/pixll.dev/public_html/mail.pixll.dev --server letsencrypt --force
[07.04.2021_10-49-46] Successfully obtained SSL for: mail.pixll.dev and: www.mail.pixll.dev
[07.04.2021_10-49-46] Websites matching query does not exist. [installSSLForDomain:72]
[07.04.2021_10-52-09] We had errors while creating DNS records for: pixll.dev. Error message: [Errno 13] Permission denied: ‘/usr/local/CyberCP/lib/python3.8/site-packages/tldextract/.suffix_cache/publicsuffix.org-tlds/de84b5ca2167d4c83e38fb162f2e8738.tldextract.json.lock’
[07.04.2021_10-52-53] Trying to obtain SSL for: pixll.dev and: www.pixll.dev
[07.04.2021_10-52-53] /root/.acme.sh/acme.sh --issue -d pixll.dev -d www.pixll.dev --cert-file /etc/letsencrypt/live/pixll.dev/cert.pem --key-file /etc/letsencrypt/live/pixll.dev/privkey.pem --fullchain-file /etc/letsencrypt/live/pixll.dev/fullchain.pem -w /home/pixll.dev/public_html --server letsencrypt --force
[07.04.2021_10-52-54] Failed to obtain SSL for: pixll.dev and: www.pixll.dev
[07.04.2021_10-52-54] Trying to obtain SSL for: pixll.dev
[07.04.2021_10-52-55] Failed to obtain SSL, issuing self-signed SSL for: pixll.dev
[07.04.2021_10-52-55] Self signed SSL issued for pixll.dev.
andy
July 13, 2021, 10:53pm
8
Same or similar problem, but I get an Invalid Certificate Error
after I re-installed a certificate at the host level and busted it…
NET::ERR_CERT_INVALID
Subject: www.example.com
Did this but still for my root domain get error
[02.17.2022_22-20-00] /root/.acme.sh/acme.sh --issue -d ola.lv -d www.ola.lv --cert-file /etc/letsencrypt/live/ola.lv/cert.pem --key-file /etc/letsencrypt/live/ola.lv/privkey.pem --fullchain-file /etc/letsencrypt/live/ola.lv/fullchain.pem -w /home/ola.lv/public_html -k ec-256 --force --server letsencrypt
[02.17.2022_22-20-02] Failed to obtain SSL for: ola.lv and: www.ola.lv
[02.17.2022_22-20-02] Trying to obtain SSL for: ola.lv
[02.17.2022_22-20-03] Failed to obtain SSL, issuing self-signed SSL for: ola.lv
[02.17.2022_22-20-03] {'[email protected] ': (554, b'5.7.1 <[email protected] >: Relay access denied')}
[02.17.2022_22-20-03] Self signed SSL issued for ola.lv.
[02.17.2022_22-22-55] Trying to obtain SSL for: ola.lv and: www.ola.lv
[02.17.2022_22-22-55] /root/.acme.sh/acme.sh --issue -d ola.lv -d www.ola.lv --cert-file /etc/letsencrypt/live/ola.lv/cert.pem --key-file /etc/letsencrypt/live/ola.lv/privkey.pem --fullchain-file /etc/letsencrypt/live/ola.lv/fullchain.pem -w /home/ola.lv/public_html -k ec-256 --force --server letsencrypt
[02.17.2022_22-22-57] Failed to obtain SSL for: ola.lv and: www.ola.lv
[02.17.2022_22-22-57] Trying to obtain SSL for: ola.lv
[02.17.2022_22-22-59] Failed to obtain SSL, issuing self-signed SSL for: ola.lv
[02.17.2022_22-22-59] {'[email protected] ': (554, b'5.7.1 <[email protected] >: Relay access denied')}
[02.17.2022_22-22-59] Self signed SSL issued for ola.lv.
[02.17.2022_22-40-12] Trying to obtain SSL for: ola.lv and: www.ola.lv
[02.17.2022_22-40-12] /root/.acme.sh/acme.sh --issue -d ola.lv -d www.ola.lv --cert-file /etc/letsencrypt/live/ola.lv/cert.pem --key-file /etc/letsencrypt/live/ola.lv/privkey.pem --fullchain-file /etc/letsencrypt/live/ola.lv/fullchain.pem -w /home/ola.lv/public_html -k ec-256 --force --server letsencrypt
[02.17.2022_22-40-13] Failed to obtain SSL for: ola.lv and: www.ola.lv
[02.17.2022_22-40-13] Trying to obtain SSL for: ola.lv
[02.17.2022_22-40-15] Failed to obtain SSL, issuing self-signed SSL for: ola.lv
[02.17.2022_22-40-15] {'[email protected] ': (554, b'5.7.1 <[email protected] >: Relay access denied')}
[02.17.2022_22-40-15] Self signed SSL issued for ola.lv.
[02.17.2022_22-40-25] Trying to obtain SSL for: mail.ola.lv and: www.mail.ola.lv
[02.17.2022_22-40-25] /root/.acme.sh/acme.sh --issue -d mail.ola.lv -d www.mail.ola.lv --cert-file /etc/letsencrypt/live/mail.ola.lv/cert.pem --key-file /etc/letsencrypt/live/mail.ola.lv/privkey.pem --fullchain-file /etc/letsencrypt/live/mail.ola.lv/fullchain.pem -w /home/ola.lv/mail.ola.lv -k ec-256 --force --server letsencrypt
[02.17.2022_22-40-38] Successfully obtained SSL for: mail.ola.lv and: www.mail.ola.lv
[02.17.2022_22-40-38] {'[email protected] ': (554, b'5.7.1 <[email protected] >: Relay access denied')}
[02.17.2022_22-40-38] Websites matching query does not exist. [installSSLForDomain:72]
for mail.ola.lv it worked
but for root domain it all the time gives self signed ssl.
have been at it for 4 days already and no luck.
Any help would be apriciated!
have u tried to issue SSL from cyberpanel ?
and please do not do “issue” more than 5 times per domain for a week, there is a limitation
Yes, I try it from panel, and all the time it gives those logs.
actually what domain we talking here ?
If anyone have this command in cyberpanel main log just update your cyberpanel and issue SSL and all will work fine.
