Hello
I updated Cyberpanel to v2.4 build 4 on Ubuntu 22.04. I had ModSecurity turned ON in Cyberpanel. I also have CPGuard installed on my server. After the update, I could still login to Cyberpanel but all my wordpress sites gave a 520 error and not accessible.
I asked CPGuard team to check, and this is what they found:
This seems to be an issue with the OLS ModSec module and it is not recognizing the ModSec module…given below is an example error:
modsecurity_rules_file /usr/local/lsws/conf/modsec.conf failed, ret -1, reason: ‘Rules error. File: <>. Line: 10. Column: 56. Invalid input: modsecurity_rules_file /usr/local/lsws/conf/modsec.conf’.
It appears the issue is coming from the OpenLiteSpeed ModSecurity module, as it is failing to load any ModSec rules. This is an error with OLS + ModSecurity.
Please contact CyberPanel support to have this fixed on the server.
Can Cyberpanel support team have a look at this issue?
FYI, I also tried a fresh install of Cyberpanel on Ubuntu 22.04 with dummy wordpress site on it. As soon as I installed and turned on ModSecurity from inside Cyberpanel, my sites will throw 520 error.
Hope any support team can help
Thanks
