Is Docker working with Almalinux9xx
using the GUI to install, it hangs on this:
Last metadata expiration check: 2:33:11 ago on Fri 03 Jan 2025 03:05:47 AM UTC.
Dependencies resolved.
Package Architecture Version Repository Size
Installing:
yum-utils noarch 4.3.0-16.el9 baseos 35 k
Transaction Summary
Install 1 Package
Total download size: 35 k
Installed size: 23 k
Downloading Packages:
yum-utils-4.3.0-16.el9.noarch.rpm 2.4 MB/s | 35 kB 00:00
Total 91 kB/s | 35 kB 00:00
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Installing : yum-utils-4.3.0-16.el9.noarch 1/1
Running scriptlet: yum-utils-4.3.0-16.el9.noarch 1/1
Verifying : yum-utils-4.3.0-16.el9.noarch 1/1
Installed:
Complete!
Last metadata expiration check: 2:33:12 ago on Fri 03 Jan 2025 03:05:47 AM UTC.
Package yum-utils-4.3.0-16.el9.noarch is already installed.
Nothing to do.
Complete!
Adding repo from: https://download.docker.com/linux/centos/docker-ce.repo
Docker CE Stable - x86_64 2.2 MB/s | 61 kB 00:00
Package Arch Version Repository Size
Installing:
containerd.io x86_64 1.7.24-3.1.el9 docker-ce-stable 43 M
docker-ce x86_64 3:27.4.1-1.el9 docker-ce-stable 27 M
docker-ce-cli x86_64 1:27.4.1-1.el9 docker-ce-stable 8.0 M
docker-compose-plugin x86_64 2.32.1-1.el9 docker-ce-stable 14 M
Installing dependencies:
container-selinux noarch 3:2.232.1-1.el9 appstream 55 k
fuse-overlayfs x86_64 1.14-1.el9 appstream 66 k
fuse3 x86_64 3.10.2-9.el9 appstream 53 k
fuse3-libs x86_64 3.10.2-9.el9 appstream 90 k
libslirp x86_64 4.4.0-8.el9 appstream 67 k
slirp4netns x86_64 1.3.1-1.el9 appstream 46 k
Installing weak dependencies:
docker-buildx-plugin x86_64 0.19.3-1.el9 docker-ce-stable 14 M
docker-ce-rootless-extras x86_64 27.4.1-1.el9 docker-ce-stable 4.4 M
Transaction Summary
Install 12 Packages
Total download size: 110 M
Installed size: 430 M
(1/12): fuse3-3.10.2-9.el9.x86_64.rpm 3.2 MB/s | 53 kB 00:00
(2/12): container-selinux-2.232.1-1.el9.noarch. 3.2 MB/s | 55 kB 00:00
(3/12): fuse-overlayfs-1.14-1.el9.x86_64.rpm 3.7 MB/s | 66 kB 00:00
(4/12): slirp4netns-1.3.1-1.el9.x86_64.rpm 9.3 MB/s | 46 kB 00:00
(5/12): libslirp-4.4.0-8.el9.x86_64.rpm 6.2 MB/s | 67 kB 00:00
(6/12): fuse3-libs-3.10.2-9.el9.x86_64.rpm 7.6 MB/s | 90 kB 00:00
(7/12): docker-buildx-plugin-0.19.3-1.el9.x86_6 41 MB/s | 14 MB 00:00
(8/12): docker-ce-27.4.1-1.el9.x86_64.rpm 37 MB/s | 27 MB 00:00
(9/12): docker-ce-cli-27.4.1-1.el9.x86_64.rpm 19 MB/s | 8.0 MB 00:00
(10/12): docker-ce-rootless-extras-27.4.1-1.el9 25 MB/s | 4.4 MB 00:00
(11/12): docker-compose-plugin-2.32.1-1.el9.x86 40 MB/s | 14 MB 00:00
(12/12): containerd.io-1.7.24-3.1.el9.x86_64.rp 36 MB/s | 43 MB 00:01
Total 70 MB/s | 110 MB 00:01
Docker CE Stable - x86_64 151 kB/s | 1.6 kB 00:00
Importing GPG key 0x621E9F35:
Userid : “Docker Release (CE rpm) [email protected]
Fingerprint: 060A 61C5 1B55 8A7F 742B 77AA C52F EB6B 621E 9F35
Key imported successfully
Running transaction
Preparing : 1/1
Installing : docker-compose-plugin-2.32.1-1.el9.x86_64 1/12
Running scriptlet: docker-compose-plugin-2.32.1-1.el9.x86_64 1/12
Installing : fuse3-libs-3.10.2-9.el9.x86_64 2/12
Running scriptlet: container-selinux-3:2.232.1-1.el9.noarch 3/12
Installing : container-selinux-3:2.232.1-1.el9.noarch 3/12
Installing : containerd.io-1.7.24-3.1.el9.x86_64 4/12
Running scriptlet: containerd.io-1.7.24-3.1.el9.x86_64 4/12
Installing : fuse3-3.10.2-9.el9.x86_64 5/12
Installing : fuse-overlayfs-1.14-1.el9.x86_64 6/12
Running scriptlet: fuse-overlayfs-1.14-1.el9.x86_64 6/12
Installing : docker-buildx-plugin-0.19.3-1.el9.x86_64 7/12
Running scriptlet: docker-buildx-plugin-0.19.3-1.el9.x86_64 7/12
Installing : docker-ce-cli-1:27.4.1-1.el9.x86_64 8/12
Running scriptlet: docker-ce-cli-1:27.4.1-1.el9.x86_64 8/12
Installing : libslirp-4.4.0-8.el9.x86_64 9/12
Installing : slirp4netns-1.3.1-1.el9.x86_64 10/12
Installing : docker-ce-rootless-extras-27.4.1-1.el9.x86_64 11/12
Running scriptlet: docker-ce-rootless-extras-27.4.1-1.el9.x86_64 11/12
Installing : docker-ce-3:27.4.1-1.el9.x86_64 12/12
Running scriptlet: docker-ce-3:27.4.1-1.el9.x86_64 12/12
Running scriptlet: container-selinux-3:2.232.1-1.el9.noarch 12/12
is Docker even smart to trust Cyberpanel to run on?
Refreshing the page shows installation completed btw
but the question is still valid - is it woorking on Alma9 and is anyone using Docker/cyberpanl in production?
I dont even know how you back up a docker setup in cyberpanel when the server dies ( and it always does)
Hello @litespeedlover
  1. Installations can hang if there are unresolved dependencies or conflicts with existing packages.
  2. High cpu steal or memory usage can affect the installation process use htop or top to check top processes. The system might be overloaded when trying to install
  3. Check if you have sufficient disk space left. Lack of enough disk space can cause installs to hang.
  4. Docker manager has worked well since v2.3.6 after important bugs were fixed.
  5. Docker container backups: Most frameworks or software that can be dockerised have ways to backup your volumes etc. Like n8n you can use a workflow that triggers at specific intervals to back up your database and workflows to some local directory where cyberpanel backups can take over the backup process to remote cloud.
