Hey I was wondering is it easy to hack or get into our control panel by a hacker? My browser always shows a warning that it’s not secure. I might be wrong that’s why I wanted to know how difficult is to hack our panel?
It’s best practice to encrypt user information and luckily CyberPanel makes it very easy to enable SSL and enforce HTTPS instead of HTTP with Rewrite Rules. You can even config your CyberPanel to be accessed at panel.example.com instead of panel.example.com:8090.
There’s more risk of your password being leaked if you are not using SSL. So I would recommend that you access your panel with a valid hostname and SSL.
