Yes i know what are the requirements, but i have actualy VPS which contract going on. It is a 10 GB HDD (for all), 1 GB ram etc. After the installation of OS the free space down ofcourse.
is it possible to install on fresh OS with less than 10 GB, and maybe decrease or cancel swap partition also?
In order to install CyberPanel you need to meet following requirements:
Installed CentOS 7 or Ubuntu 18.04 LTS operating system
Installed Python 2.7
Minimum 1 GB of RAM (I recommend at least 2 GB of RAM)
10 GB of space available on drive
root access (or use sudo when running commands to get root privileges)
static IP address reserved for your server
I personaly would advice a bit more power. 1GB Ram will not make you happy.
And you can install it on 10GB HD, but eventually you will not have enough space to run backups of websites (depends on the amount of data you store). We just figured aout, that runnig a backup will nedd the Websites space three (3) times while runnig backup.
