Hi everyone,
i want to install ioncube but webterminal is not connected, have a nother way for install, and i need to install as soon as possible…
some is can be help me for it…
thanks
Hi everyone,
thanks
Log into your server via SSH and follow this tutorial
https://forums.cyberpanel.net/discussion/228/install-ioncube-loader-on-openlitespeed
If you want to use the CyberPanel terminal, you need to secure your login to the panel since the built-in terminal only works when the panel is secure.
cannot open that link
How install ion cube loader in php 8.0.14 ?
this code just install in php 7.4 apt-get install lsphp74-ioncube
I used this : apt-get install lsphp80-ioncube but got error
Please check if ubuntu have ioncube for lsphp run
apt list lsphp*
