How can i install ImageMagick on my server running Cyberpanel?
It should be installed by default. If not, then on the left menu of Cyberpanel under PHP option you will find an option named “Install Extensions”. Click on it and then select the PHP version you need imagemagick and you will find the option to install it.
For which version of php and what is you OS?
