Hello
Note: Deprecated, main installation is now Python 3.
Testing on CyberPanel with Python 3 support is going on. Yon can install and test using following command
Update: It also support Centos 8 now, however Centos8 does not have official opendkim package so DKIM related features will not work.
Note: Don’t use in production.
sh <(curl cyberpanel.sh || wget -O - cyberpanel.sh)
During installation , it will pop to ask you if you want to try python3 branch.
type “confirm” to proceed to python 3 branch.
omit it or press enter key or type “n” will proceed as normal installation.
Report any bugs here.
Regards
can this be used with CentOS 8?
Regards,
qtwrk
December 17, 2019, 3:02pm
#3
Regards,
I don’t think so , CentOS 8 support is still on to-do
Once basic testing on Centos 7.x is completed, we will move on to Centos 8 integration.
Great job, thanks CyberPanel
avhvr
December 24, 2019, 5:13pm
#6
Can this be used in production in Ubuntu 18?
qtwrk
December 24, 2019, 5:21pm
#7
No, python 3 branch is only beta for now
Olá, ao subir o site para instalar, recebi o seguinte erro.:403
Forbidden
Access to this resource on the server is denied!
Como concertar isso?
qtwrk
December 31, 2019, 10:37pm
#9
Forbidden
Could you please provide a screenshot? Where you got 403?
netbos
January 3, 2020, 10:25pm
#10
Type your comment> @qtwrk said:
Forbidden
Thanks to your commit
committed 03:18PM - 03 Jan 20 UTC
I’ve found that script on my ubuntu systems works using bash while failing on sh
I think there might be more to this.
using
sh <(curl https://raw.githubusercontent.com/usmannasir/cyberpanel/stable/preUpgrade.sh )
from looking at the upgrade process it’s been failing to apply source command with error not found
While
bash <(curl https://raw.githubusercontent.com/usmannasir/cyberpanel/stable/preUpgrade.sh )
Done it just right. All working perfectly.
It might be just two of my custom environments but still, it does make sense.
It would be much appreciated if you know (and want to share) what’s (or possibly could) causing this.
Is it .profile ~/.{.bashrc,.bash_profile} /etc/{bash.bashrc,profile} content as I think it is?
@EDIT3 not relate to this thinking by the looks of thing
Well technically I’ve not used full
<(curl https://raw.githubusercontent.com/usmannasir/cyberpanel/stable/preUpgrade.sh || wget -O - https://raw.githubusercontent.com/usmannasir/cyberpanel/stable/preUpgrade.sh )
during my test, there is also that
EOF named not think about it
qtwrk
January 3, 2020, 10:26pm
#11
Forbidden
fix UnicodeDecodeError during installation · usmannasir/cyberpanel@e8ecec7 · GitHub
using
While
yes, Usman used some bash programm , but I believe I have converted it to shell.
netbos
January 3, 2020, 10:33pm
#12
Forbidden
using
While
That’s quicker than i expected. Respect mate d{^_^}b
Not work Language after update v1.9.3
qtwrk
January 4, 2020, 10:46pm
#14
what do you mean ?
You change your language and stay in english
ioncube PHP Extension
Loaded plugins: fastestmirror
Rewrite Rules not work 1.9.3
Could not connect to server. Please refresh this page.
Forbidden
Olá, o erros 404, consertei: https://www.temqueve.com.br/erros-404-wordpress-openlitespeed/
