Hi, hence cyberpanel can only be installed on centos7 , as for now. and many people asking for other Linux distro, so I spent couple hours googling Docker as it can be deployed on many different system.
NOTE: this is TESTING only , do NOT use it on production server.
I have tested image on centos7.4 and debian9.4 , and tested as much functions as possible , but this is NOT guaranteed bug-free, so please feel free to report any problem you’ve encountered.
If you encountered a issue or bug , please try first if it can be reproduced on standard installation to ruled out if it’s due to Docker or bug in cyberpanel itself.
Install Docker
Install and start docker by following the docker documents
for CentOS
for Debian
for Ubuntu
Check if port 25 is already in use by postfix (Centos) and exim4 (Debian)
netstat -lnp | grep 25
if so , stop it first , otherwise it will conflict with cyberpanel’s mail function.
for Centos
systemctl stop postfix
systemctl disable postfix
for Debian
systemctl stop exim4
systemctl disable exim4
Install CyberPanel
Option 1: Pre-Built Image
wget https://mirror.cyberpanel.net/docker/cyberpanel.img
Download the pre-built docker image
docker import cyberpanel.img
Import the image
docker images
Check the images , and note the image ID
docker run --restart always -p 8090:8090 -p 80:80 -p 443:443 -p 21:21 -p 25:25 -p 587:587 -p 465:465 -p 110:110 -p 143:143 -p 993:993 -p 53:53 -p 53:53/udp -p 7080:7080 -p 40110-40210:40110-40210 -d -i -t -e "container=docker" --privileged=true -v /sys/fs/cgroup:/sys/fs/cgroup --name cyberpanel IMAGE_ID /usr/sbin/init
Replace the IMAGE_ID ( 2rd to last ) with the image ID you see in previous command.
This will start docker with 21/25/53/80/110/143/465/587/993/7080/8090 port.
docker exec -it cyberpanel /bin/bash
Now enter the container.
there are 2 things I have noticed ,
first: modify the IP in /etc/cyberpanel/machineIP
you can do this by sed command
sed -i 's/127.0.0.1/YOUR_SERVER_IP/g' /etc/cyberpanel/machineIP
second: if you have multiple CPU machine , you need to get into OpenLiteSpeed WebAdmin Console to manually bind more CPU into listener(s)
Option 2: New install inside container
docker pull centos
Get Centos image as base
docker run --restart always -p 8090:8090 -p 80:80 -p 443:443 -p 21:21 -p 25:25 -p 587:587 -p 465:465 -p 110:110 -p 143:143 -p 993:993 -p 53:53 -p 53:53/udp -p 7080:7080 -p 40110-40210:40110-40210 -d -i -t -e "container=docker" --privileged=true -v /sys/fs/cgroup:/sys/fs/cgroup --name cyberpanel centos /usr/sbin/init
Start docker container
Enter container
Now you can install it as usual way
sh <(curl https://mirror.cyberpanel.net/install-cn.sh || wget -O - https://mirror.cyberpanel.net/install-cn.sh)
mirror server is located in German , it should be OK to serve worldwide , so please report the download speed
or
if you facing a CPU @ 100% by tty1 service
run this in both container and host
systemctl stop [email protected]
systemctl mask [email protected]
