I’ve bought a few Laravel scripts from Codecanyon. I have no clue how to install them. All these scripts assume that I have a cPanel so I’m a bit lost.
Is there any easy steps on how to do it in CyberPanel?
Thank you.
Welcome @Zane Happy you are here
Before doing that you will need to setup PHP [TUTORIAL] How to install any PHP modules using PEAR Package Manager
Kindly contact the author of the scripts to help you install the scripts. For most authors this is always free or they offer documentation for you to follow.
On CyberPanel you can create a website where you can run any web apps, apis inside /home/mydomain.com/public_html for example
