I am trying to install CyberPanel on Almalinux 8.
The installer keeps stopping all the time. It stops at different stages.
I have no idea what’s wrong.
The installer isn’t prepared to resume installations, some things it will only do once and will break when attempting again.
Reinstall your OS, and run the installer.
When it gives you an error post it here so we can then help you
Share more details your system os, provider where it is stopping and all
System OS: AlmaLinux 8, Provider: Self-Hosted Dedicated Server.
I solved the problem by installing CentOS 7 and running the installer again. This time it didn’t stop anywhere and runs just fine.
I will make a new topic if I decide to try AlmaLinux 8 another time.
