To see what’s going on, I tried $docker – info
Got the following output:
Client:
Debug Mode: false
Server:
ERROR: error during connect: Get http://%2Fvar%2Frun%2Fdocker.sock/v1.40/info: read unix @->/var/run/docker.sock: read: connection reset by peer
errors pretty printing info
I tried to start docker on command line
$sudo systemctl start docker
A dependency job for docker.service failed. See ‘journalctl -xe’ for details.
Here’s the content from journalctl -xe , after I tried to start Docker on the command line:
– Subject: Process /usr/bin/containerd could not be executed
– Defined-By: systemd
– Support: Enterprise open source support | Ubuntu
– The process /usr/bin/containerd could not be executed and failed.
– The error number returned by this process is 1.
Sep 16 01:09:04 inspiredearth.nz systemd[1]: containerd.service: Main process exited, code=exited, status
Sep 16 01:09:04 inspiredearth.nz systemd[1]: containerd.service: Failed with result ‘exit-code’.
Sep 16 01:09:04 inspiredearth.nz systemd[1]: containerd.service: Service hold-off time over, scheduling r
Sep 16 01:09:04 inspiredearth.nz systemd[1]: containerd.service: Scheduled restart job, restart counter i
– Subject: Automatic restarting of a unit has been scheduled
– Automatic restarting of the unit containerd.service has been scheduled, as the result for
– the configured Restart= setting for the unit.
Sep 16 01:09:04 inspiredearth.nz systemd[1]: Stopped containerd container runtime.
– Subject: Unit containerd.service has finished shutting down
– Unit containerd.service has finished shutting down.
Sep 16 01:09:04 inspiredearth.nz systemd[1]: containerd.service: Start request repeated too quickly.
Sep 16 01:09:04 inspiredearth.nz systemd[1]: Failed to start containerd container runtime.
– Subject: Unit containerd.service has failed
– Unit containerd.service has failed.
– The result is RESULT.
Sep 16 01:09:16 inspiredearth.nz sudo[2247]: inspired : TTY=pts/0 ; PWD=/home/inspired ; USER=root ; COMM
Sep 16 01:09:16 inspiredearth.nz sudo[2247]: pam_unix(sudo:session): session opened for user root by insp
lines 3182-3216/3216 (END)
Sep 16 01:09:04 inspiredearth.nz systemd[1]: containerd.service: Main process exited, code=exited, status=205/LIMITS
Sep 16 01:09:04 inspiredearth.nz systemd[1]: containerd.service: Service hold-off time over, scheduling restart.
Sep 16 01:09:04 inspiredearth.nz systemd[1]: containerd.service: Scheduled restart job, restart counter is at 5.
lines 3182-3214/3216 100%
