I am on Ubuntu 22.04.3 LTS with latest Cyberpanel update today.
I am trying to install WordPress on a new domain but always get this error.
Installation failed. Error message: [“can only concatenate str (not "NoneType") to str [404]”]
Screenshot: YibyX73.png (934×352) (imgur.com)
Now, can’t install any website on the VPS
Note: It seems happened after I installed PHP 8.2 on the server.
Please help.
Thanks
What happens if you change it to any other php version ?
Same error after changed to other PHP versions.
Latest Build: 4
Latest Commit:
36c0d62e786508b028f5757c64933412d3cd596b
Can you enable debug logs and share main log file contents?
Please tell me how to enable debug logs and the path to get main log file contents?
Thanks
I open the /usr/local/lsws/logs/error.log file by the command tail -f error.log and below are the latest results.
2023-11-28 07:44:23.379662 [NOTICE] [8926] Setup swapping space…
2023-11-28 07:44:23.379732 [NOTICE] [8926] LiteSpeed/1.7.18 Open starts successfully!
2023-11-28 07:44:23.431725 [NOTICE] [8768] [AutoRestarter] child process with pid=8773 exited with status=0!
2023-11-28 07:44:23.431793 [NOTICE] [8768] [AutoRestarter] cleanup children processes and unix sockets belong to process 8774 !
2023-11-28 07:44:23.531881 [NOTICE] [8768] [AutoRestarter] child process with pid=8774 exited with status=0!
2023-11-28 07:44:23.531997 [NOTICE] [8768] Server Stopped!
These are LSWS Logs, please check this video: https://www.youtube.com/watch?v=MfdO_iE5MD4
The log file when I enabled debug like in your video
root@GCSing:/home/cyberpanel# tail -f /home/cyberpanel/error-logs.txt
[11.28.2023_07-20-13] Expecting value: line 1 column 1 (char 0)
[11.28.2023_07-23-12] https://api.github.com/repos/usmannasir/cyberpanel/commits?sha=v2.3.4
[11.28.2023_07-42-56] Config path: /etc/apache2/sites-enabled/tinhtan.vn.conf
[11.28.2023_07-44-23] Config path: /etc/apache2/sites-enabled/tinhtan.vn.conf
[11.28.2023_07-57-06] Status Code: 200 for: http://www.tinhtan.vn/.well-known/acme-challenge/tinhtan.vn
[11.28.2023_07-57-06] Status Code: 200 for: http://tinhtan.vn/.well-known/acme-challenge/tinhtan.vn
[11.28.2023_07-57-22] /root/.acme.sh/acme.sh --issue -d tinhtan.vn -d www.tinhtan.vn --cert-file /etc/letsencrypt/live/tinhtan.vn/cert.pem --key-file /etc/letsencrypt/live/tinhtan.vn/privkey.pem --fullchain-file /etc/letsencrypt/live/tinhtan.vn/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[11.28.2023_07-57-29] Successfully obtained SSL for: tinhtan.vn and: www.tinhtan.vn
[11.28.2023_07-57-29] {‘[email protected] ’: (554, b’5.7.1 [email protected] : Relay access denied’)}
[11.28.2023_07-58-03] Config path: /etc/apache2/sites-enabled/tinhtan.vn.conf
[11.28.2023_08-05-35] wo9+iEboy5tvMstCnwBGQFBtxK15qUgbsudo chown -R cyberpanel:cyberpanel /home/cyberpanel
[11.28.2023_08-05-35] wo9+iEboy5tvMstCnwBGQFBtxK15qUgbsudo wp --info
[11.28.2023_08-05-35] wo9+iEboy5tvMstCnwBGQFBtxK15qUgbsudo /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/virtualHostUtilities.py changePHP --phpVersion ‘PHP 8.0’ --path /usr/local/lsws/conf/vhosts/tinhtan.vn/vhost.conf
[11.28.2023_08-05-36] Config path: /etc/apache2/sites-enabled/tinhtan.vn.conf
[11.28.2023_08-05-36] sudo -u tinht5367 touch /home/tinhtan.vn/.lsphp_restart.txt
[11.28.2023_08-05-39] systemctl restart lsws
[11.28.2023_08-05-39] sudo -u tinht5367 rm -f /home/tinhtan.vn/.lsphp_restart.txt
whats the output of
ls -la /usr/local/lsws/lsphp80/bin
drwxr-xr-x 2 root root 4096 Oct 16 08:37 .
drwxr-xr-x 9 root root 4096 Oct 16 08:37 …
-rwxr-xr-x 1 root root 16038936 Aug 4 14:50 lsphp
-rwxr-xr-x 1 root root 888 Aug 10 2022 pear
-rwxr-xr-x 1 root root 909 Aug 10 2022 peardev
-rwxr-xr-x 1 root root 822 Aug 10 2022 pecl
lrwxrwxrwx 1 root root 12 Aug 4 14:50 phar8.0 → phar8.0.phar
-rwxr-xr-x 1 root root 15396 Aug 4 14:50 phar8.0.phar
-rwxr-xr-x 1 root root 16143024 Aug 4 14:50 php
-rwxr-xr-x 1 root root 16143024 Aug 4 14:50 php8.0
-rwxr-xr-x 1 root root 5137 Aug 4 14:50 php-config
-rwxr-xr-x 1 root root 5137 Aug 4 14:50 php-config8.0
-rwxr-xr-x 1 root root 7368 Aug 8 2022 phpdismod
-rwxr-xr-x 1 root root 7368 Aug 4 15:38 phpenmod
-rwxr-xr-x 1 root root 4757 Aug 4 15:38 php-helper
-rwxr-xr-x 1 root root 4571 Aug 4 14:50 phpize
-rwxr-xr-x 1 root root 4571 Aug 4 14:50 phpize8.0
-rwxr-xr-x 1 root root 9778 Aug 4 15:38 php-maintscript-helper
-rwxr-xr-x 1 root root 6382 Aug 4 15:38 phpquery
-rwxr-xr-x 1 root root 2841 Aug 4 15:38 sessionclean
Note: The trouble happened in my two VPS(s) so I guess the latest commit has a problem.
I am trying to allow using SSH login using password and after restart SSH and try to login myself and I get blocked, not sure. Will fix the trouble and PM you the root login and the CP details soon.
Thanks
I’ve sent you the PM with login details.
Thanks for your help
I am going to check the server now.
I pushed a minor update, all of the people having problem should update to see if it is resolved.
gokok
November 28, 2023, 9:16pm
18
The same issue.
I will check with update.
gokok
November 28, 2023, 9:26pm
19
Everything goes OK. Creating path, downloading wordpress, installing and activating LS Cache plugin.
Thanks a lot.
Anyone still having issue after updating?
I upgraded Cyberpanel on both servers and everything is ok now.
Thanks
