While doing a fresh install of CentOS 8 + CyberPanel v2.1.1
./cyberpanel.sh: line 1348: cd: /tmp/cyberpanel/install/lsmcd-master: No such file or directory
Assuming it has something to do with “LiteSpeed Memcached”, so answering [No] to Memcached support during setup process should avoid this error.
Ideas?
qtwrk
2
to me it looks like a network glitch
you can ignore this error if you don’t use LSMCD
or manually install it litespeed_wiki:lsmcd:installation [LiteSpeed Wiki]
I will see if I can add some check and test on installer to avoid such issue.
It only seems to happen in CentOS Linux 8 & CentOS Stream 8.
Centos 7.x worked just fine.
