Here is my install.log ![]()
I would like to use the powerdns feature and some other things.
But look like there is a lot of errors…
Is it normal to get so much errors?
What do I need to do please?
Thanks.
[-00-29] Starting CyberPanel installation…,10
[-00-29] Running: dd if=/dev/zero of=/usr/.tempdisk bs=100M count=15,10
[-00-38] Successfully ran: dd if=/dev/zero of=/usr/.tempdisk bs=100M count=15.,10
[-00-39] Running: mkfs.ext4 -F /usr/.tempdisk,10
[-00-43] Successfully ran: mkfs.ext4 -F /usr/.tempdisk.,10
[-00-43] Running: mkdir -p /usr/.tmpbak/,10
[-00-44] Successfully ran: mkdir -p /usr/.tmpbak/.,10
[-00-44] Running: mount -o loop-rw-nodev-nosuid-noexec-nofail /usr/.tempdisk /tmp,10
[-00-44] Successfully ran: mount -o loop-rw-nodev-nosuid-noexec-nofail /usr/.tempdisk /tmp.,10
[-00-45] Running: chmod 1777 /tmp,10
[-00-45] Successfully ran: chmod 1777 /tmp.,10
[-00-45] Running: rm -rf /usr/.tmpbak,10
[-00-45] Successfully ran: rm -rf /usr/.tmpbak.,10
[-00-46] Running: mount --bind /tmp /var/tmp,10
[-00-46] Successfully ran: mount --bind /tmp /var/tmp.,10
[-00-46] Running: adduser --disabled-login --gecos “” cyberpanel,10
[-00-47] Successfully ran: adduser --disabled-login --gecos “” cyberpanel.,10
[-00-47] Running: adduser --disabled-login --gecos “” docker,10
[-00-47] Successfully ran: adduser --disabled-login --gecos “” docker.,10
[-00-48] Running: groupadd docker,10
[-00-48] [ERROR] We are not able to run groupadd docker return code: 9.,10
[-00-48] Running: usermod -aG docker docker,10
[-00-48] Successfully ran: usermod -aG docker docker.,10
[-00-49] Running: usermod -aG docker cyberpanel,10
[-00-49] Successfully ran: usermod -aG docker cyberpanel.,10
[-00-49] Running: mkdir -p /etc/letsencrypt/live/,10
[-00-50] Successfully ran: mkdir -p /etc/letsencrypt/live/.,10
[-00-50] Running: wget http://rpms.litespeedtech.com/debian/enable_lst_debain_repo.sh,10
[-00-50] Successfully ran: wget http://rpms.litespeedtech.com/debian/enable_lst_debain_repo.sh.,10
[-00-51] Running: ./enable_lst_debain_repo.sh,10
[-00-54] Successfully ran: ./enable_lst_debain_repo.sh.,10
[-00-54] Running: ,10
[-00-55] Successfully ran: .,10
[-00-55] Running: ,10
[-00-55] Installing LiteSpeed Web server,40
[-00-56] Running: DEBIAN_FRONTEND=noninteractive apt-get -y install openlitespeed,40
[-01-18] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get -y install openlitespeed.,40
[-01-19] Changing default port to 80…,40
[-01-19] Default port is now 80 for OpenLiteSpeed!,40
[-01-19] Running: /usr/local/lsws/bin/lswsctrl restart,40
[-01-22] Successfully ran: /usr/local/lsws/bin/lswsctrl restart.,40
[-01-23] Installing Optimized PHPs…,50
[-02-21] LiteSpeed PHPs successfully installed!,50
[-02-22] Fixing OpenLiteSpeed configurations!,50
[-02-22] OpenLiteSpeed Configurations fixed!,50
[-02-22] Running: /usr/local/lsws/bin/lswsctrl restart,50
[-02-25] Successfully ran: /usr/local/lsws/bin/lswsctrl restart.,50
[-02-26] Installing MySQL,60
[-02-26] Running: DEBIAN_FRONTEND=noninteractive apt-get -y install mariadb-server,60
[-02-37] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get -y install mariadb-server.,60
[-02-37] Running: systemctl start mariadb,60
[-02-37] Successfully ran: systemctl start mariadb.,60
[-02-38] Running: systemctl enable mariadb,60
[-02-39] Successfully ran: systemctl enable mariadb.,60
[-02-39] [ERROR] We are not able to run mysql -u root -e “use mysql;DROP DATABASE IF EXISTS test;DELETE FROM mysql.db WHERE Db=‘test’ OR Db=‘test_%’;GRANT ALL PRIVILEGES ON . TO ‘root’@‘localhost’ IDENTIFIED BY ‘bclTHUaFD7OCkg’;UPDATE user SET plugin=‘’ WHERE User=‘root’;flush privileges;” return code: 1.,60
[-02-40] Running: systemctl start mariadb,60
[-02-40] Successfully ran: systemctl start mariadb.,60
[-02-40] Running: systemctl enable mariadb,60
[-02-42] Successfully ran: systemctl enable mariadb.,60
[-03-20] Running: systemctl enable pure-ftpd-mysql,60
[-03-21] Successfully ran: systemctl enable pure-ftpd-mysql.,60
[-03-22] Running: groupadd -g 2001 ftpgroup,60
[-03-22] Successfully ran: groupadd -g 2001 ftpgroup.,60
[-03-22] Running: useradd -u 2001 -s /bin/false -d /bin/null -c “pureftpd user” -g ftpgroup ftpuser,60
[-03-22] Successfully ran: useradd -u 2001 -s /bin/false -d /bin/null -c “pureftpd user” -g ftpgroup ftpuser.,60
[-03-23] Configuring PureFTPD…,60
[-03-23] [ERROR] Could not create directory for FTP SSL,60
[-03-23] Running: openssl req -x509 -nodes -days 7300 -newkey rsa:2048 -subj “/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com” -keyout /etc/ssl/private/pure-ftpd.pem -out /etc/ssl/private/pure-ftpd.pem,60
[-03-24] Successfully ran: openssl req -x509 -nodes -days 7300 -newkey rsa:2048 -subj “/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com” -keyout /etc/ssl/private/pure-ftpd.pem -out /etc/ssl/private/pure-ftpd.pem.,60
[-03-24] Running: ln -s /etc/pure-ftpd/conf/MySQLConfigFile /etc/pure-ftpd/auth/30mysql,60
[-03-24] Successfully ran: ln -s /etc/pure-ftpd/conf/MySQLConfigFile /etc/pure-ftpd/auth/30mysql.,60
[-03-25] Running: ln -s /etc/pure-ftpd/conf/UnixAuthentication /etc/pure-ftpd/auth/65unix,60
[-03-25] Successfully ran: ln -s /etc/pure-ftpd/conf/UnixAuthentication /etc/pure-ftpd/auth/65unix.,60
[-03-25] Running: systemctl restart pure-ftpd-mysql.service,60
[-03-26] Successfully ran: systemctl restart pure-ftpd-mysql.service.,60
[-03-26] PureFTPD configured!,60
[-03-26] Running: systemctl start pure-ftpd-mysql,60
[-03-26] Successfully ran: systemctl start pure-ftpd-mysql.,60
[-03-27] Running: systemctl stop systemd-resolved,60
[-03-27] Successfully ran: systemctl stop systemd-resolved.,60
[-03-27] Running: systemctl disable systemd-resolved.service,60
[-03-28] Successfully ran: systemctl disable systemd-resolved.service.,60
[-03-33] Configuring PowerDNS…,60
[-03-34] PowerDNS configured!,60
[-03-34] Running: systemctl enable pdns,60
[-03-35] Successfully ran: systemctl enable pdns.,60
[-03-35] Running: systemctl start pdns,60
[-03-35] Successfully ran: systemctl start pdns.,60
[-03-35] Running: chmod +x composer.sh,60
[-03-36] Successfully ran: chmod +x composer.sh.,60
[-03-36] Running: ./composer.sh,60
[-03-38] Successfully ran: ./composer.sh.,60
[-03-38] [ERROR] fix_selinux_issue problem,60
[-03-38] Running: DEBIAN_FRONTEND=noninteractive apt-get -y install psmisc,60
[-03-39] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get -y install psmisc.,60
[-03-39] Running: DEBIAN_FRONTEND=noninteractive apt-get -y remove postfix,60
[-03-40] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get -y remove postfix.,60
[-03-40] Running: DEBIAN_FRONTEND=noninteractive apt-get -y install debconf-utils,60
[-03-44] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get -y install debconf-utils.,60
[-03-45] Running: debconf-set-selections /root/cyberpanel/install/pf.unattend.text,60
[-03-45] Successfully ran: debconf-set-selections /root/cyberpanel/install/pf.unattend.text.,60
[-03-46] Running: DEBIAN_FRONTEND=noninteractive apt-get -y install postfix postfix-mysql,60
[-04-04] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get -y install postfix postfix-mysql.,60
[-04-04] Running: DEBIAN_FRONTEND=noninteractive apt-get -y install dovecot-mysql dovecot-imapd dovecot-pop3d,60
[-04-20] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get -y install dovecot-mysql dovecot-imapd dovecot-pop3d.,60
[-04-21] Setting up authentication for Postfix and Dovecot…,60
[-04-21] Authentication for Postfix and Dovecot set.,60
[-04-21] Configuring postfix and dovecot…,60
[-04-21] Running: openssl req -newkey rsa:2048 -new -nodes -x509 -days 3650 -subj “/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com” -keyout /etc/postfix/key.pem -out /etc/postfix/cert.pem,60
[-04-22] Successfully ran: openssl req -newkey rsa:2048 -new -nodes -x509 -days 3650 -subj “/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com” -keyout /etc/postfix/key.pem -out /etc/postfix/cert.pem.,60
[-04-23] Running: openssl req -newkey rsa:2048 -new -nodes -x509 -days 3650 -subj “/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com” -keyout /etc/dovecot/key.pem -out /etc/dovecot/cert.pem,60
[-04-23] Successfully ran: openssl req -newkey rsa:2048 -new -nodes -x509 -days 3650 -subj “/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com” -keyout /etc/dovecot/key.pem -out /etc/dovecot/cert.pem.,60
[-04-24] Cleanup postfix/dovecot config files,60
[-04-24] Running: postconf -e ‘myhostname = localhost’,60
[-04-24] Successfully ran: postconf -e ‘myhostname = localhost’.,60
[-04-24] Running: sed -i ‘s|server.example.com|localhost|g’ /etc/postfix/main.cf,60
[-04-25] Successfully ran: sed -i ‘s|server.example.com|localhost|g’ /etc/postfix/main.cf.,60
[-04-25] Running: chmod o= /etc/postfix/mysql-virtual_domains.cf,60
[-04-25] Successfully ran: chmod o= /etc/postfix/mysql-virtual_domains.cf.,60
[-04-25] Running: chmod o= /etc/postfix/mysql-virtual_forwardings.cf,60
[-04-26] Successfully ran: chmod o= /etc/postfix/mysql-virtual_forwardings.cf.,60
[-04-26] Running: chmod o= /etc/postfix/mysql-virtual_mailboxes.cf,60
[-04-26] Successfully ran: chmod o= /etc/postfix/mysql-virtual_mailboxes.cf.,60
[-04-27] Running: chmod o= /etc/postfix/mysql-virtual_email2email.cf,60
[-04-27] Successfully ran: chmod o= /etc/postfix/mysql-virtual_email2email.cf.,60
[-04-27] Running: chmod o= /etc/postfix/main.cf,60
[-04-27] Successfully ran: chmod o= /etc/postfix/main.cf.,60
[-04-28] Running: chmod o= /etc/postfix/master.cf,60
[-04-28] Successfully ran: chmod o= /etc/postfix/master.cf.,60
[-04-28] Running: chgrp postfix /etc/postfix/mysql-virtual_domains.cf,60
[-04-29] Successfully ran: chgrp postfix /etc/postfix/mysql-virtual_domains.cf.,60
[-04-29] Running: chgrp postfix /etc/postfix/mysql-virtual_forwardings.cf,60
[-04-29] Successfully ran: chgrp postfix /etc/postfix/mysql-virtual_forwardings.cf.,60
[-04-29] Running: chgrp postfix /etc/postfix/mysql-virtual_mailboxes.cf,60
[-04-30] Successfully ran: chgrp postfix /etc/postfix/mysql-virtual_mailboxes.cf.,60
[-04-30] Running: chgrp postfix /etc/postfix/mysql-virtual_email2email.cf,60
[-04-30] Successfully ran: chgrp postfix /etc/postfix/mysql-virtual_email2email.cf.,60
[-04-30] Running: chgrp postfix /etc/postfix/main.cf,60
[-04-31] Successfully ran: chgrp postfix /etc/postfix/main.cf.,60
[-04-31] Running: chgrp postfix /etc/postfix/master.cf,60
[-04-31] Successfully ran: chgrp postfix /etc/postfix/master.cf.,60
[-04-32] Running: groupadd -g 5000 vmail,60
[-04-32] Successfully ran: groupadd -g 5000 vmail.,60
[-04-32] Running: useradd -g vmail -u 5000 vmail -d /home/vmail -m,60
[-04-32] Successfully ran: useradd -g vmail -u 5000 vmail -d /home/vmail -m.,60
[-04-33] Running: systemctl enable postfix.service,60
[-04-34] Successfully ran: systemctl enable postfix.service.,60
[-04-35] Running: systemctl start postfix.service,60
[-04-35] Successfully ran: systemctl start postfix.service.,60
[-04-35] Running: chgrp dovecot /etc/dovecot/dovecot-sql.conf.ext,60
[-04-35] Successfully ran: chgrp dovecot /etc/dovecot/dovecot-sql.conf.ext.,60
[-04-36] Running: chmod o= /etc/dovecot/dovecot-sql.conf.ext,60
[-04-36] Successfully ran: chmod o= /etc/dovecot/dovecot-sql.conf.ext.,60
[-04-36] Running: systemctl enable dovecot.service,60
[-04-38] Successfully ran: systemctl enable dovecot.service.,60
[-04-38] Running: systemctl start dovecot.service,60
[-04-38] Successfully ran: systemctl start dovecot.service.,60
[-04-39] Running: systemctl restart postfix.service,60
[-04-40] Successfully ran: systemctl restart postfix.service.,60
[-04-40] Running: chmod 755 /etc/postfix/main.cf,60
[-04-40] Successfully ran: chmod 755 /etc/postfix/main.cf.,60
[-04-40] Running: mkdir -p /etc/pki/dovecot/private/,60
[-04-41] Successfully ran: mkdir -p /etc/pki/dovecot/private/.,60
[-04-41] Running: mkdir -p /etc/pki/dovecot/certs/,60
[-04-42] Successfully ran: mkdir -p /etc/pki/dovecot/certs/.,60
[-04-42] Running: mkdir -p /etc/opendkim/keys/,60
[-04-42] Successfully ran: mkdir -p /etc/opendkim/keys/.,60
[-04-42] Running: sed -i ‘s/auth_mechanisms = plain/#auth_mechanisms = plain/g’ /etc/dovecot/conf.d/10-auth.conf,60
[-04-43] Successfully ran: sed -i ‘s/auth_mechanisms = plain/#auth_mechanisms = plain/g’ /etc/dovecot/conf.d/10-auth.conf.,60
[-04-43] Running: systemctl restart dovecot,60
[-04-45] Successfully ran: systemctl restart dovecot.,60
[-04-45] Postfix and Dovecot configured,60
[-04-45] Running: DEBIAN_FRONTEND=noninteractive apt-get -y install unzip,60
[-04-46] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get -y install unzip.,60
[-04-46] Running: DEBIAN_FRONTEND=noninteractive apt-get -y install zip,60
[-04-47] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get -y install zip.,60
[-04-47] Running: DEBIAN_FRONTEND=noninteractive apt-get -y install rsync,60
[-04-48] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get -y install rsync.,60
[-04-49] Checking to see if ufw firewall is installed (will be removed),60
[-04-49] Running: Remove ufw firewall (using firewalld),60
[-04-53] Successfully ran: Remove ufw firewall (using firewalld).,60
[-04-54] Running: DEBIAN_FRONTEND=noninteractive apt-get -y install firewalld,60
[-05-01] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get -y install firewalld.,60
[-05-01] Running: systemctl restart systemd-logind,60
[-05-06] Successfully ran: systemctl restart systemd-logind.,60
[-05-06] Running: systemctl start firewalld,60
[-05-06] Successfully ran: systemctl start firewalld.,60
[-05-07] Running: systemctl enable firewalld,60
[-05-08] Successfully ran: systemctl enable firewalld.,60
[-05-28] FirewallD installed and configured!,60
[-05-28] Running: ssh-keygen -f /root/.ssh/cyberpanel -t rsa -N ‘’,60
[-05-30] Successfully ran: ssh-keygen -f /root/.ssh/cyberpanel -t rsa -N ‘’.,60
[-05-30] Running: echo downloaded,60
[-05-31] Successfully ran: echo downloaded.,60
[-05-31] Updating /root/.my.cnf!,60
[-05-31] Updating settings.py!,60
[-05-32] settings.py updated!,60
[-05-32] Running: /usr/local/CyberPanel/bin/python manage.py makemigrations,60
[-05-35] Successfully ran: /usr/local/CyberPanel/bin/python manage.py makemigrations.,60
[-05-35] Running: /usr/local/CyberPanel/bin/python manage.py migrate,60
[-05-40] Successfully ran: /usr/local/CyberPanel/bin/python manage.py migrate.,60
[-05-41] Running: /usr/local/CyberPanel/bin/python manage.py collectstatic --noinput --clear,60
[-05-43] Successfully ran: /usr/local/CyberPanel/bin/python manage.py collectstatic --noinput --clear.,60
[-05-43] Running: mv static /usr/local/CyberCP/public/,60
[-05-44] Successfully ran: mv static /usr/local/CyberCP/public/.,60
[-05-44] Running: wget https://github.com/the-djmaze/snappymail/releases/download/v2.25.3/snappymail-2.25.3.zip,60
[-05-45] Successfully ran: wget https://github.com/the-djmaze/snappymail/releases/download/v2.25.3/snappymail-2.25.3.zip.,60
[-05-45] Running: unzip snappymail-2.25.3.zip -d /usr/local/CyberCP/public/snappymail,60
[-05-45] Successfully ran: unzip snappymail-2.25.3.zip -d /usr/local/CyberCP/public/snappymail.,60
[-05-46] Running: find . -type d -exec chmod 755 {} ;,60
[-05-46] Successfully ran: find . -type d -exec chmod 755 {} ;.,60
[-05-47] Running: find . -type f -exec chmod 644 {} ;,60
[-05-48] Successfully ran: find . -type f -exec chmod 644 {} ;.,60
[-05-48] Running: mkdir -p /usr/local/lscp/cyberpanel/rainloop/data,60
[-05-48] Successfully ran: mkdir -p /usr/local/lscp/cyberpanel/rainloop/data.,60
[-05-49] Running: mkdir -p /usr/local/lscp/cyberpanel/rainloop/data/data/default/configs/,60
[-05-49] Successfully ran: mkdir -p /usr/local/lscp/cyberpanel/rainloop/data/data/default/configs/.,60
[-05-49] Running: wget -O /usr/local/CyberCP/snappymail_cyberpanel.php https://raw.githubusercontent.com/the-djmaze/snappymail/master/integrations/cyberpanel/install.php,60
[-05-50] Successfully ran: wget -O /usr/local/CyberCP/snappymail_cyberpanel.php https://raw.githubusercontent.com/the-djmaze/snappymail/master/integrations/cyberpanel/install.php.,60
[-05-50] Running: /usr/local/lsws/lsphp74/bin/php /usr/local/CyberCP/snappymail_cyberpanel.php,60
[-05-51] Successfully ran: /usr/local/lsws/lsphp74/bin/php /usr/local/CyberCP/snappymail_cyberpanel.php.,60
[-05-51] Running: wget -O /usr/local/CyberCP/public/phpmyadmin.zip https://github.com/usmannasir/cyberpanel/raw/stable/phpmyadmin.zip,60
[-05-53] Successfully ran: wget -O /usr/local/CyberCP/public/phpmyadmin.zip https://github.com/usmannasir/cyberpanel/raw/stable/phpmyadmin.zip.,60
[-05-53] Running: unzip /usr/local/CyberCP/public/phpmyadmin.zip -d /usr/local/CyberCP/public/phpmyadmin,60
[-05-54] Successfully ran: unzip /usr/local/CyberCP/public/phpmyadmin.zip -d /usr/local/CyberCP/public/phpmyadmin.,60
[-05-54] Running: rm -f /usr/local/CyberCP/public/phpmyadmin.zip,60
[-05-55] Successfully ran: rm -f /usr/local/CyberCP/public/phpmyadmin.zip.,60
[-05-55] Running: chown -R lscpd:lscpd /usr/local/CyberCP/public/phpmyadmin,60
[-05-56] [ERROR] We are not able to run chown -R lscpd:lscpd /usr/local/CyberCP/public/phpmyadmin return code: 1.,60
[-05-56] Running: cp /usr/local/CyberCP/plogical/phpmyadminsignin.php /usr/local/CyberCP/public/phpmyadmin/phpmyadminsignin.php,60
[-05-56] Successfully ran: cp /usr/local/CyberCP/plogical/phpmyadminsignin.php /usr/local/CyberCP/public/phpmyadmin/phpmyadminsignin.php.,60
[-05-57] Running: ln -s /usr/local/CyberCP/cli/cyberPanel.py /usr/bin/cyberpanel,60
[-05-57] Successfully ran: ln -s /usr/local/CyberCP/cli/cyberPanel.py /usr/bin/cyberpanel.,60
[-05-57] Running: chmod +x /usr/local/CyberCP/cli/cyberPanel.py,60
[-05-58] Successfully ran: chmod +x /usr/local/CyberCP/cli/cyberPanel.py.,60
[-05-58] Running: DEBIAN_FRONTEND=noninteractive apt-get -y install cron,60
[-05-59] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get -y install cron.,60
[-05-59] Running: systemctl enable cron,60
[-06-01] Successfully ran: systemctl enable cron.,60
[-06-01] Running: systemctl start cron,60
[-06-01] Successfully ran: systemctl start cron.,60
[-06-02] Running: chmod 600 /var/spool/cron/crontabs/root,60
[-06-02] Successfully ran: chmod 600 /var/spool/cron/crontabs/root.,60
[-06-03] Running: systemctl restart cron.service,60
[-06-03] Successfully ran: systemctl restart cron.service.,60
[-06-04] Running: DEBIAN_FRONTEND=noninteractive apt-get update -y,60
[-06-06] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get update -y.,60
[-06-07] Running: DEBIAN_FRONTEND=noninteractive apt-get install restic -y,60
[-06-11] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get install restic -y.,60
[-06-11] Running: restic self-update,60
[-06-15] Successfully ran: restic self-update.,60
[-06-16] Running: echo acme2,60
[-06-16] Successfully ran: echo acme2.,60
[-06-16] Running: DEBIAN_FRONTEND=noninteractive apt-get -y install opendkim,60
[-06-22] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get -y install opendkim.,60
[-06-23] Running: apt install opendkim-tools -y,60
[-06-24] Successfully ran: apt install opendkim-tools -y.,60
[-06-24] Running: mkdir -p /etc/opendkim/keys/,60
[-06-24] Successfully ran: mkdir -p /etc/opendkim/keys/.,60
[-06-25] Running: systemctl start opendkim,60
[-06-25] Successfully ran: systemctl start opendkim.,60
[-06-25] Running: systemctl enable opendkim,60
[-06-28] Successfully ran: systemctl enable opendkim.,60
[-06-28] Running: systemctl start postfix,60
[-06-29] Successfully ran: systemctl start postfix.,60
[-06-29] [ERROR] [Errno 2] No such file or directory: ‘/usr/local/lsws/modules/mod_security.so’ [modSecPreReqs],60
[-06-29] Starting LSCPD installation…,60
[-06-29] Running: DEBIAN_FRONTEND=noninteractive apt-get -y install gcc g++ make autoconf rcs,60
[-06-30] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get -y install gcc g++ make autoconf rcs.,60
[-06-31] Running: DEBIAN_FRONTEND=noninteractive apt-get -y install libpcre3 libpcre3-dev openssl libexpat1 libexpat1-dev libgeoip-dev zlib1g zlib1g-dev libudns-dev whichman curl,60
[-06-36] Successfully ran: DEBIAN_FRONTEND=noninteractive apt-get -y install libpcre3 libpcre3-dev openssl libexpat1 libexpat1-dev libgeoip-dev zlib1g zlib1g-dev libudns-dev whichman curl.,60
[-06-36] Running: tar zxf lscp.tar.gz -C /usr/local/,60
[-06-38] Successfully ran: tar zxf lscp.tar.gz -C /usr/local/.,60
[-06-38] Running: cp -f /usr/local/CyberCP/lscpd.0.4.0 /usr/local/lscp/bin/lscpd.0.4.0,60
[-06-39] Successfully ran: cp -f /usr/local/CyberCP/lscpd.0.4.0 /usr/local/lscp/bin/lscpd.0.4.0.,60
[-06-39] Running: rm -f /usr/local/lscp/bin/lscpd,60
[-06-39] Successfully ran: rm -f /usr/local/lscp/bin/lscpd.,60
[-06-40] Running: mv /usr/local/lscp/bin/lscpd.0.4.0 /usr/local/lscp/bin/lscpd,60
[-06-40] Successfully ran: mv /usr/local/lscp/bin/lscpd.0.4.0 /usr/local/lscp/bin/lscpd.,60
[-06-40] Running: chmod 755 /usr/local/lscp/bin/lscpd,60
[-06-40] Successfully ran: chmod 755 /usr/local/lscp/bin/lscpd.,60
[-06-41] Running: openssl req -newkey rsa:1024 -new -nodes -x509 -days 3650 -subj “/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com” -keyout /usr/local/lscp/conf/key.pem -out /usr/local/lscp/conf/cert.pem,60
[-06-41] Successfully ran: openssl req -newkey rsa:1024 -new -nodes -x509 -days 3650 -subj “/C=US/ST=Denial/L=Springfield/O=Dis/CN=www.example.com” -keyout /usr/local/lscp/conf/key.pem -out /usr/local/lscp/conf/cert.pem.,60
[-06-41] Running: useradd lscpd -M -d /usr/local/lscp,60
[-06-42] Successfully ran: useradd lscpd -M -d /usr/local/lscp.,60
[-06-42] Running: usermod -a -G lscpd lscpd,60
[-06-42] Successfully ran: usermod -a -G lscpd lscpd.,60
[-06-42] Running: usermod -a -G lsadm lscpd,60
[-06-43] Successfully ran: usermod -a -G lsadm lscpd.,60
[-06-43] LSCPD successfully installed!,60
[-06-43] Running: wget http://www.litespeedtech.com/packages/lsapi/wsgi-lsapi-2.1.tgz,60
[-06-44] Successfully ran: wget http://www.litespeedtech.com/packages/lsapi/wsgi-lsapi-2.1.tgz.,60
[-06-44] Running: tar xf wsgi-lsapi-2.1.tgz,60
[-06-45] Successfully ran: tar xf wsgi-lsapi-2.1.tgz.,60
[-06-45] Running: /usr/local/CyberPanel/bin/python ./configure.py,60
[-06-45] Successfully ran: /usr/local/CyberPanel/bin/python ./configure.py.,60
[-06-45] Running: make,60
[-06-47] Successfully ran: make.,60
[-06-47] Running: cp lswsgi /usr/local/CyberCP/bin/,60
[-06-48] Successfully ran: cp lswsgi /usr/local/CyberCP/bin/.,60
[-06-48] Trying to setup LSCPD Daemon!,60
[-06-48] Running: chmod +x /usr/local/lscp/bin/lscpdctrl,60
[-06-48] Successfully ran: chmod +x /usr/local/lscp/bin/lscpdctrl.,60
[-06-49] Running: mkdir -p /usr/local/lscpd/admin/,60
[-06-49] Successfully ran: mkdir -p /usr/local/lscpd/admin/.,60
[-06-49] Running: mkdir -p /usr/local/CyberCP/conf/,60
[-06-50] Successfully ran: mkdir -p /usr/local/CyberCP/conf/.,60
[-06-50] Running: chmod 600 /usr/local/CyberCP/conf/token_env,60
[-06-50] Successfully ran: chmod 600 /usr/local/CyberCP/conf/token_env.,60
[-06-50] Running: systemctl enable lscpd.service,60
[-06-51] Successfully ran: systemctl enable lscpd.service.,60
[-06-51] Running: ln -s /lib/x86_64-linux-gnu/libpcre.so.3 /lib/x86_64-linux-gnu/libpcre.so.1,60
[-06-52] Successfully ran: ln -s /lib/x86_64-linux-gnu/libpcre.so.3 /lib/x86_64-linux-gnu/libpcre.so.1.,60
[-06-52] LSCPD Daemon Set!,60
[-06-52] Running: usermod -G lscpd-lsadm-nobody lscpd,60
[-06-53] [ERROR] We are not able to run usermod -G lscpd-lsadm-nobody lscpd return code: 6.,60
[-06-53] Running: usermod -G lscpd-lsadm-nogroup lscpd,60
[-06-53] Successfully ran: usermod -G lscpd-lsadm-nogroup lscpd.,60
[-06-53] Running: find /usr/local/CyberCP -type d -exec chmod 0755 {} ;,60
[-06-56] Successfully ran: find /usr/local/CyberCP -type d -exec chmod 0755 {} ;.,60
[-06-56] Running: find /usr/local/CyberCP -type f -exec chmod 0644 {} ;,60
[-05] Successfully ran: find /usr/local/CyberCP -type f -exec chmod 0644 {} ;.,60
[-05] Running: chmod -R 755 /usr/local/CyberCP/bin,60
[-06] Successfully ran: chmod -R 755 /usr/local/CyberCP/bin.,60
[-06] Running: chown -R root:root /usr/local/CyberCP,60
[-06] Successfully ran: chown -R root:root /usr/local/CyberCP.,60
[-06] Running: find /usr/local/lscp -type d -exec chmod 0755 {} ;,60
[-07] Successfully ran: find /usr/local/lscp -type d -exec chmod 0755 {} ;.,60
[-07] Running: find /usr/local/lscp -type f -exec chmod 0644 {} ;,60
[-07] Successfully ran: find /usr/local/lscp -type f -exec chmod 0644 {} ;.,60
[-08] Running: chmod -R 755 /usr/local/lscp/bin,60
[-08] Successfully ran: chmod -R 755 /usr/local/lscp/bin.,60
[-08] Running: chmod -R 755 /usr/local/lscp/fcgi-bin,60
[-08] Successfully ran: chmod -R 755 /usr/local/lscp/fcgi-bin.,60
[-09] Running: chown -R lscpd:lscpd /usr/local/CyberCP/public/phpmyadmin/tmp,60
[-09] Successfully ran: chown -R lscpd:lscpd /usr/local/CyberCP/public/phpmyadmin/tmp.,60
[-09] Running: chown -R root:root /usr/local/lscp,60
[-10] Successfully ran: chown -R root:root /usr/local/lscp.,60
[-10] Running: chown -R lscpd:lscpd /usr/local/lscp/cyberpanel/rainloop,60
[-10] Successfully ran: chown -R lscpd:lscpd /usr/local/lscp/cyberpanel/rainloop.,60
[-10] Running: chmod 700 /usr/local/CyberCP/cli/cyberPanel.py,60
[-11] Successfully ran: chmod 700 /usr/local/CyberCP/cli/cyberPanel.py.,60
[-11] Running: chmod 700 /usr/local/CyberCP/plogical/upgradeCritical.py,60
[-11] Successfully ran: chmod 700 /usr/local/CyberCP/plogical/upgradeCritical.py.,60
[-12] Running: chmod 755 /usr/local/CyberCP/postfixSenderPolicy/client.py,60
[-12] Successfully ran: chmod 755 /usr/local/CyberCP/postfixSenderPolicy/client.py.,60
[-12] Running: chmod 640 /usr/local/CyberCP/CyberCP/settings.py,60
[-12] Successfully ran: chmod 640 /usr/local/CyberCP/CyberCP/settings.py.,60
[-13] Running: chown root:cyberpanel /usr/local/CyberCP/CyberCP/settings.py,60
[-13] Successfully ran: chown root:cyberpanel /usr/local/CyberCP/CyberCP/settings.py.,60
[-13] Running: chmod 644 /etc/yum.repos.d/MariaDB.repo,60
[-14] [ERROR] We are not able to run chmod 644 /etc/yum.repos.d/MariaDB.repo return code: 1.,60
[-14] Running: chmod 644 /etc/pdns/pdns.conf,60
[-14] [ERROR] We are not able to run chmod 644 /etc/pdns/pdns.conf return code: 1.,60
[-14] Running: chmod 644 /etc/systemd/system/lscpd.service,60
[-15] Successfully ran: chmod 644 /etc/systemd/system/lscpd.service.,60
[-15] Running: chmod 644 /etc/pure-ftpd/pure-ftpd.conf,60
[-16] Successfully ran: chmod 644 /etc/pure-ftpd/pure-ftpd.conf.,60
[-16] Running: chmod 644 /etc/pure-ftpd/pureftpd-pgsql.conf,60
[-16] Successfully ran: chmod 644 /etc/pure-ftpd/pureftpd-pgsql.conf.,60
[-16] Running: chmod 644 /etc/pure-ftpd/pureftpd-mysql.conf,60
[-17] Successfully ran: chmod 644 /etc/pure-ftpd/pureftpd-mysql.conf.,60
[-17] Running: chmod 644 /etc/pure-ftpd/pureftpd-ldap.conf,60
[-17] Successfully ran: chmod 644 /etc/pure-ftpd/pureftpd-ldap.conf.,60
[-18] Running: chmod 644 /etc/dovecot/dovecot.conf,60
[-18] Successfully ran: chmod 644 /etc/dovecot/dovecot.conf.,60
[-18] Running: chmod 644 /usr/local/lsws/conf/httpd_config.xml,60
[-18] [ERROR] We are not able to run chmod 644 /usr/local/lsws/conf/httpd_config.xml return code: 1.,60
[-19] Running: chmod 644 /usr/local/lsws/conf/modsec.conf,60
[-19] [ERROR] We are not able to run chmod 644 /usr/local/lsws/conf/modsec.conf return code: 1.,60
[-19] Running: chmod 644 /usr/local/lsws/conf/httpd.conf,60
[-20] [ERROR] We are not able to run chmod 644 /usr/local/lsws/conf/httpd.conf return code: 1.,60
[-20] Running: chmod 600 /etc/pure-ftpd/pure-ftpd.conf,60
[-20] Successfully ran: chmod 600 /etc/pure-ftpd/pure-ftpd.conf.,60
[-20] Running: chmod 600 /etc/pure-ftpd/pureftpd-pgsql.conf,60
[-21] Successfully ran: chmod 600 /etc/pure-ftpd/pureftpd-pgsql.conf.,60
[-21] Running: chmod 600 /etc/pure-ftpd/pureftpd-mysql.conf,60
[-21] Successfully ran: chmod 600 /etc/pure-ftpd/pureftpd-mysql.conf.,60
[-21] Running: chmod 600 /etc/pure-ftpd/pureftpd-ldap.conf,60
[-22] Successfully ran: chmod 600 /etc/pure-ftpd/pureftpd-ldap.conf.,60
[-22] Running: chmod 600 /etc/dovecot/dovecot.conf,60
[-22] Successfully ran: chmod 600 /etc/dovecot/dovecot.conf.,60
[-23] Running: chmod 600 /etc/pdns/pdns.conf,60
[-23] [ERROR] We are not able to run chmod 600 /etc/pdns/pdns.conf return code: 1.,60
[-23] Running: chmod 600 /etc/pure-ftpd/db/mysql.conf,60
[-23] Successfully ran: chmod 600 /etc/pure-ftpd/db/mysql.conf.,60
[-24] Running: chmod 600 /etc/powerdns/pdns.conf,60
[-24] Successfully ran: chmod 600 /etc/powerdns/pdns.conf.,60
[-24] Running: chmod +x /usr/local/CyberCP/plogical/renew.py,60
[-25] Successfully ran: chmod +x /usr/local/CyberCP/plogical/renew.py.,60
[-25] Running: chmod +x /usr/local/CyberCP/CLManager/CLPackages.py,60
[-25] Successfully ran: chmod +x /usr/local/CyberCP/CLManager/CLPackages.py.,60
[-25] Running: chmod +x /usr/local/CyberCP/CLScript/panel_info.py,60
[-26] Successfully ran: chmod +x /usr/local/CyberCP/CLScript/panel_info.py.,60
[-26] Running: chmod +x /usr/local/CyberCP/CLScript/CloudLinuxPackages.py,60
[-26] Successfully ran: chmod +x /usr/local/CyberCP/CLScript/CloudLinuxPackages.py.,60
[-26] Running: chmod +x /usr/local/CyberCP/CLScript/CloudLinuxUsers.py,60
[-27] Successfully ran: chmod +x /usr/local/CyberCP/CLScript/CloudLinuxUsers.py.,60
[-27] Running: chmod +x /usr/local/CyberCP/CLScript/CloudLinuxDomains.py,60
[-27] Successfully ran: chmod +x /usr/local/CyberCP/CLScript/CloudLinuxDomains.py.,60
[-28] Running: chmod +x /usr/local/CyberCP/CLScript/CloudLinuxResellers.py,60
[-28] Successfully ran: chmod +x /usr/local/CyberCP/CLScript/CloudLinuxResellers.py.,60
[-28] Running: chmod +x /usr/local/CyberCP/CLScript/CloudLinuxAdmins.py,60
[-28] Successfully ran: chmod +x /usr/local/CyberCP/CLScript/CloudLinuxAdmins.py.,60
[-29] Running: chmod +x /usr/local/CyberCP/CLScript/CloudLinuxDB.py,60
[-29] Successfully ran: chmod +x /usr/local/CyberCP/CLScript/CloudLinuxDB.py.,60
[-29] Running: chmod +x /usr/local/CyberCP/CLScript/UserInfo.py,60
[-30] Successfully ran: chmod +x /usr/local/CyberCP/CLScript/UserInfo.py.,60
[-30] Running: chmod 600 /usr/local/CyberCP/plogical/adminPass.py,60
[-30] Successfully ran: chmod 600 /usr/local/CyberCP/plogical/adminPass.py.,60
[-30] Running: chmod 600 /etc/cagefs/exclude/cyberpanelexclude,60
[-31] [ERROR] We are not able to run chmod 600 /etc/cagefs/exclude/cyberpanelexclude return code: 1.,60
[-31] Running: find /usr/local/CyberCP/ -name ‘*.pyc’ -delete,60
[-31] Successfully ran: find /usr/local/CyberCP/ -name ‘*.pyc’ -delete.,60
[-32] Running: chown root:pdns /etc/powerdns/pdns.conf,60
[-32] Successfully ran: chown root:pdns /etc/powerdns/pdns.conf.,60
[-32] Running: chmod 640 /etc/powerdns/pdns.conf,60
[-32] Successfully ran: chmod 640 /etc/powerdns/pdns.conf.,60
[-33] Running: chmod 640 /usr/local/lscp/cyberpanel/logs/access.log,60
[-33] [ERROR] We are not able to run chmod 640 /usr/local/lscp/cyberpanel/logs/access.log return code: 1.,60
[-34] Running: chmod 600 /usr/local/CyberCP/public/snappymail.php,60
[-34] [ERROR] We are not able to run chmod 600 /usr/local/CyberCP/public/snappymail.php return code: 1.,60
[-34] Running: mount -o remount-rw-hidepid=2 /proc,60
[-34] Successfully ran: mount -o remount-rw-hidepid=2 /proc.,60
[-35] Running: sysctl --system,60
[-35] Successfully ran: sysctl --system.,60
[-35] Running: chmod 700 /home/cyberpanel,60
[-36] Successfully ran: chmod 700 /home/cyberpanel.,60
[-36] Running: chmod 600 /usr/local/lscp/conf/key.pem,60
[-36] Successfully ran: chmod 600 /usr/local/lscp/conf/key.pem.,60
[-36] CyberPanel installation successfully completed!,80
