from 3 day i try to install CyberPanel but every time return me this error:
[ERROR] We are not able to run rpm -ivh http://rpms.litespeedtech.com/centos/litespeed-repo-1.2-1.el7.noarch.rpm return code: 1. Fatal error, see /var/log/installLogs.txt for full details.
When i open the file /var/log/installLogs.txt, his have only this content:
Starting installation…,1
Initialization completed…,2
command failed, exiting. For more information read /var/log/installLogs.txt [404]
Setting up repositories…,1
Installing necessary components…,3
Installing required virtual enviroment,3
Installing requirments…,3
Getting CyberPanel code…,4
Necessary components installed…,5
Setting up sytem tweak…,20
Starting main installation…,30
[05.22.2021_23-36-47] Starting CyberPanel installation…,10
[05.22.2021_23-36-47] Running: yum install sudo -y,10
[05.22.2021_23-36-51] Successfully ran: yum install sudo -y.,10
[05.22.2021_23-36-51] Running: useradd -s /bin/false cyberpanel,10
[05.22.2021_23-36-51] Successfully ran: useradd -s /bin/false cyberpanel.,10
[05.22.2021_23-36-52] Running: adduser docker,10
[05.22.2021_23-36-52] Successfully ran: adduser docker.,10
[05.22.2021_23-36-52] Running: groupadd docker,10
[05.22.2021_23-36-52] [ERROR] We are not able to run groupadd docker return code: 9.,10
[05.22.2021_23-36-53] Running: usermod -aG docker docker,10
[05.22.2021_23-36-53] Successfully ran: usermod -aG docker docker.,10
[05.22.2021_23-36-53] Running: usermod -aG docker cyberpanel,10
[05.22.2021_23-36-53] Successfully ran: usermod -aG docker cyberpanel.,10
[05.22.2021_23-36-54] Running: mkdir -p /etc/letsencrypt/live/,10
[05.22.2021_23-36-54] Successfully ran: mkdir -p /etc/letsencrypt/live/.,10
[05.22.2021_23-36-54] Running: rpm -ivh http://rpms.litespeedtech.com/centos/litespeed-repo-1.2-1.el7.noarch.rpm,10
[05.22.2021_23-36-56] [ERROR] We are not able to run rpm -ivh http://rpms.litespeedtech.com/centos/litespeed-repo-1.2-1.el7.noarch.rpm return code: 1. Fatal error, se$
Oops, something went wrong… [404]
I really don’t understand where it’s a problem in my OS and server or in CyberPanel instalation packages?
Why is not able to run this rpm from cyberpanel server?
Any idea how to fix it?
Thank you to all in advance and please help me with this case!
