Installation error ["invalid literal for int() with base 10: '' [404]"
Hi all,
I wanted to install WordPress but I was unable to install it, it showed an error code.
installation error [“invalid literal for int() with base 10: ‘’ [404]”.
But I don’t know what it means.
This is the log file it generated.
[04.23.2023_19-51-24] Trying to obtain SSL for: Soundness.ml
[04.23.2023_19-51-41] Failed to obtain SSL, issuing self-signed SSL for: Soundness.ml
[04.23.2023_19-51-45] Self signed SSL issued for Soundness.ml.
[04.23.2023_19-51-49] systemctl restart lsws
[04.23.2023_19-51-53] systemctl restart postfix
[04.23.2023_19-51-55] systemctl restart dovecot
[04.23.2023_19-55-09] 4I86wLbdmRDVrdlXS1sRSMXntBnbH/3/sudo chown -R cyberpanel:cyberpanel /home/cyberpanel
[04.23.2023_19-55-09] 4I86wLbdmRDVrdlXS1sRSMXntBnbH/3/sudo wp --info
[04.23.2023_19-55-10] Extra data: line 1 column 2 (char 1). [setupConnection:75]
[04.23.2023_19-55-10] CREATE DATABASE Bn1FZ8nLchpljX
[04.23.2023_19-55-10] CREATE USER ‘Bn1FZ8nLchpljX’@‘localhost’ IDENTIFIED BY ‘a1qT1pBePfd0la’
[04.23.2023_19-55-11] GRANT ALL PRIVILEGES ON Bn1FZ8nLchpljX.* TO ‘Bn1FZ8nLchpljX’@‘localhost’
[04.23.2023_19-55-11] 4I86wLbdmRDVrdlXS1sRSMXntBnbH/3/-u Sound4397 mkdir -p /home/Soundness.ml/public_html/
[04.23.2023_19-55-11] string index out of range [executioner]
[04.23.2023_19-55-11] 4I86wLbdmRDVrdlXS1sRSMXntBnbH/3/-u Sound4397 ls /home/Soundness.ml/public_html/ | wc -l
[04.23.2023_19-56-07] 4I86wLbdmRDVrdlXS1sRSMXntBnbH/3/sudo chown -R cyberpanel:cyberpanel /home/cyberpanel
[04.23.2023_19-56-39] 4I86wLbdmRDVrdlXS1sRSMXntBnbH/3/sudo chown -R cyberpanel:cyberpanel /home/cyberpanel
[04.23.2023_19-56-39] 4I86wLbdmRDVrdlXS1sRSMXntBnbH/3/sudo wp --info
[04.23.2023_19-56-40] Extra data: line 1 column 2 (char 1). [setupConnection:75]
[04.23.2023_19-56-40] CREATE DATABASE GYPiluQSm8URxu
[04.23.2023_19-56-40] CREATE USER ‘GYPiluQSm8URxu’@‘localhost’ IDENTIFIED BY ‘Tfh67P1sZksgM5’
[04.23.2023_19-56-40] GRANT ALL PRIVILEGES ON GYPiluQSm8URxu.* TO ‘GYPiluQSm8URxu’@‘localhost’
[04.23.2023_19-56-40] 4I86wLbdmRDVrdlXS1sRSMXntBnbH/3/-u Sound4397 mkdir -p /home/Soundness.ml/public_html/About/
[04.23.2023_19-56-40] string index out of range [executioner]
[04.23.2023_19-56-40] 4I86wLbdmRDVrdlXS1sRSMXntBnbH/3/-u Sound4397 ls /home/Soundness.ml/public_html/About/ | wc -l
[04.24.2023_04-00-11] cat /home/Soundness.ml/logs/Soundness.ml.access_log
[04.24.2023_04-00-23] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘30 Minutes’
[04.24.2023_04-00-23] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘1 Hour’
[04.24.2023_04-30-08] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘30 Minutes’
[04.24.2023_05-00-08] cat /home/Soundness.ml/logs/Soundness.ml.access_log
[04.24.2023_05-00-19] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘1 Hour’
[04.24.2023_05-00-21] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘30 Minutes’
[04.24.2023_05-30-09] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘30 Minutes’
[04.24.2023_06-00-11] cat /home/Soundness.ml/logs/Soundness.ml.access_log
[04.24.2023_06-00-22] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘30 Minutes’
[04.24.2023_06-00-26] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘6 Hours’
[04.24.2023_06-00-27] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘1 Hour’
[04.24.2023_06-30-08] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘30 Minutes’
[04.24.2023_07-00-06] cat /home/Soundness.ml/logs/Soundness.ml.access_log
[04.24.2023_07-00-20] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘30 Minutes’
[04.24.2023_07-00-22] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘1 Hour’
[04.24.2023_07-30-09] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘30 Minutes’
[04.24.2023_08-00-10] cat /home/Soundness.ml/logs/Soundness.ml.access_log
[04.24.2023_08-00-22] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘30 Minutes’
[04.24.2023_08-00-22] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘1 Hour’
[04.24.2023_08-30-07] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘30 Minutes’
[04.24.2023_00-35-29] 4I86wLbdmRDVrdlXS1sRSMXntBnbH/3/sudo chown -R cyberpanel:cyberpanel /home/cyberpanel
[04.24.2023_09-00-05] cat /home/Soundness.ml/logs/Soundness.ml.access_log
[04.24.2023_09-00-23] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘30 Minutes’
[04.24.2023_09-00-23] /usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py ‘1 Hour’
Please can you be of help, I’m a complete novice.
