Initial Configurations not working
I reinstalled the server,
Current Version: 2.4
Build: 1Current Commit: 03e8bbbf54fcea4802396d2d17ea8aa3fec58e0f
Although A records and domain and subdomain IP forwarding are fine, hostname does not receive SSL, Initial Configurations do not work. It says Starting and stays in the same place for minutes.
I am having the same problem.
@maxwell, did you get it sorted?
My domain’s A record and rPTR are okay, but the Initial configurations remain on the same page for hours with rotating dots.
Can anyone help, please?
Check how many SSLs you have purchased from https://crt.sh/ You may be hitting the Lets Encrypt limit. I was able to solve my problem by making a different domain the host domain. You should also make sure that your AAAA (IPv6) record is working properly.
