Incoming SPF / DKIM Email Policy?
Does Cyberpanel 2.12 include any form of SPF / DKIM checking policy by default for incoming email?
I am not seeing any SPF Pass/Fail records in the headers of incoming email, even after SpamAssassin has been installed. MailScanner has DB errors and will not install, but I don’t know if this is even needed for basic SPF validation.
If so, where should I look to edit incoming SPF policy or at least ensure it is working properly?
If not, what is the best way to install/activate SPF Validation for incoming email?
Should I follow the instructions for the following article or will it break something in cyberpanel?
https://help.ubuntu.com/community/Postfix/SPF
Thanks in advance for any help.
  1. Mailscanner was impltemented by someone from community, so it is not actively maintained.
  2. You can add/delete SPF from DNS manager if your DNS is managed by CyberPanel DNS -> ADD/Delete DNS Records
You can use mail test sites to evaluate the email configuration. Here is the popular test site for you; https://www.mail-tester.com/
Thank you, but isn’t the above advice meant for OUTGOING SPF configurations? Setting up SPF in DNS and using mail-tester is meant for OUTSIDE SMTP servers to check OUR SMTP server to make sure its authorized.
I was asking about the reverse … ie INCOMING SPF. How do we enable Cyberpanel to CHECK SPF records of other SMTP servers against THEIR DNS records to help determine incoming SPAM?
Anyone know?
