I can no longer use “imunifyav” after the last update
And when you try to install “imunifyav” this error appears
root@154:~# wget https://repo.imunify360.cloudlinux.com/defence360/imav-deploy.sh
--2023-08-12 22:14:27-- https://repo.imunify360.cloudlinux.com/defence360/imav-deploy.sh
Resolving repo.imunify360.cloudlinux.com (repo.imunify360.cloudlinux.com)... 107.155.119.71
Connecting to repo.imunify360.cloudlinux.com (repo.imunify360.cloudlinux.com)|107.155.119.71|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 43007 (42K) [application/octet-stream]
Saving to: 'imav-deploy.sh.2'
imav-deploy.sh.2 100%[======================================================================================>] 42.00K --.-KB/s in 0.04s
2023-08-12 22:14:28 (1.00 MB/s) - 'imav-deploy.sh.2' saved [43007/43007]
root@154:~# bash imav-deploy.sh
[2023-08-12 22:14:44] Checking for an update to imav-deploy.sh
[2023-08-12 22:14:44] Downloading imav-deploy.sh.repo_version (please wait)
[2023-08-12 22:14:45] imav-deploy.sh is already the latest version (2.81) - continuing
Detecting ostype... debian
In a few moments the script will install latest imunify-antivirus package (w/dependencies)... (Ctrl-C to cancel)
[2023-08-12 22:15:09] Reading package lists...
[2023-08-12 22:15:09] Building dependency tree...
[2023-08-12 22:15:09] Reading state information...
[2023-08-12 22:15:09] gnupg is already the newest version (2.2.27-3ubuntu2.1).
[2023-08-12 22:15:09] 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[2023-08-12 22:15:09] 6 not fully installed or removed.
[2023-08-12 22:15:09] After this operation, 0 B of additional disk space will be used.
[2023-08-12 22:15:09] Setting up php7.3-fpm (7.3.33-11+ubuntu22.04.1+deb.sury.org+1) ...
[2023-08-12 22:15:09] NOTICE: Not enabling PHP 7.3 FPM by default.
[2023-08-12 22:15:09] NOTICE: To enable PHP 7.3 FPM in Apache2 do:
[2023-08-12 22:15:09] NOTICE: a2enmod proxy_fcgi setenvif
[2023-08-12 22:15:09] NOTICE: a2enconf php7.3-fpm
[2023-08-12 22:15:09] NOTICE: You are seeing this message because you have apache2 package installed.
[2023-08-12 22:15:09] Job for php7.3-fpm.service failed because the control process exited with error code.
[2023-08-12 22:15:09] See "systemctl status php7.3-fpm.service" and "journalctl -xeu php7.3-fpm.service" for details.
[2023-08-12 22:15:09] invoke-rc.d: initscript php7.3-fpm, action "restart" failed.
[2023-08-12 22:15:09] × php7.3-fpm.service - The PHP 7.3 FastCGI Process Manager
[2023-08-12 22:15:09] Loaded: loaded (/lib/systemd/system/php7.3-fpm.service; enabled; vendor preset: enabled)
[2023-08-12 22:15:09] Active: failed (Result: exit-code) since Sat 2023-08-12 22:14:53 EEST; 7ms ago
[2023-08-12 22:15:09] Docs: man:php-fpm7.3(8)
[2023-08-12 22:15:09] Process: 331023 ExecStart=/usr/sbin/php-fpm7.3 --nodaemonize --fpm-config /etc/php/7.3/fpm/php-fpm.conf (code=exited, status=78)
[2023-08-12 22:15:09] Process: 331024 ExecStopPost=/usr/lib/php/php-fpm-socket-helper remove /run/php/php-fpm.sock /etc/php/7.3/fpm/pool.d/www.conf 73 (code=exited, status=0/SUCCESS)
[2023-08-12 22:15:09] Main PID: 331023 (code=exited, status=78)
[2023-08-12 22:15:09] CPU: 35ms
[2023-08-12 22:15:09] Aug 12 22:14:53 xxx.xxx.xxx.xxx systemd[1]: Starting The PHP 7.3 FastCGI Process Manager...
[2023-08-12 22:15:09] Aug 12 22:14:53 xxx.xxx.xxx.xxx php-fpm7.3[331023]: [12-Aug-2023 22:14:53] WARNING: Nothing matches the include pattern '/etc/php/7.3/fpm/pool.d/*.conf' from /etc/php/7.3/fpm/php-fpm.conf at line 143.
[2023-08-12 22:15:09] Aug 12 22:14:53 xxx.xxx.xxx.xxx php-fpm7.3[331023]: [12-Aug-2023 22:14:53] ERROR: No pool defined. at least one pool section must be specified in config file
[2023-08-12 22:15:09] Aug 12 22:14:53 xxx.xxx.xxx.xxx php-fpm7.3[331023]: [12-Aug-2023 22:14:53] ERROR: failed to post process the configuration
[2023-08-12 22:15:09] Aug 12 22:14:53 xxx.xxx.xxx.xxx php-fpm7.3[331023]: [12-Aug-2023 22:14:53] ERROR: FPM initialization failed
[2023-08-12 22:15:09] Aug 12 22:14:53 xxx.xxx.xxx.xxx systemd[1]: php7.3-fpm.service: Main process exited, code=exited, status=78/CONFIG
[2023-08-12 22:15:09] Aug 12 22:14:53 xxx.xxx.xxx.xxx systemd[1]: php7.3-fpm.service: Failed with result 'exit-code'.
[2023-08-12 22:15:09] Aug 12 22:14:53 xxx.xxx.xxx.xxx systemd[1]: Failed to start The PHP 7.3 FastCGI Process Manager.
[2023-08-12 22:15:09] dpkg: error processing package php7.3-fpm (--configure):
[2023-08-12 22:15:09] installed php7.3-fpm package post-installation script subprocess returned error exit status 1
[2023-08-12 22:15:09] dpkg: dependency problems prevent configuration of php7.3:
[2023-08-12 22:15:09] php7.3 depends on libapache2-mod-php7.3 | php7.3-fpm | php7.3-cgi; however:
[2023-08-12 22:15:09] Package libapache2-mod-php7.3 is not installed.
[2023-08-12 22:15:09] Package php7.3-fpm is not configured yet.
[2023-08-12 22:15:09] Package php7.3-cgi is not installed.
[2023-08-12 22:15:09] dpkg: error processing package php7.3 (--configure):
[2023-08-12 22:15:09] dependency problems - leaving unconfigured
[2023-08-12 22:15:09] Setting up php5.6-fpm (5.6.40-66+ubuntu22.04.1+deb.sury.org+1) ...
[2023-08-12 22:15:09] No apport report written because the error message indicates its a followup error from a previous failure.
[2023-08-12 22:15:09] NOTICE: Not enabling PHP 5.6 FPM by default.
[2023-08-12 22:15:09] NOTICE: To enable PHP 5.6 FPM in Apache2 do:
[2023-08-12 22:15:09] NOTICE: a2enconf php5.6-fpm
[2023-08-12 22:15:09] Job for php5.6-fpm.service failed because the control process exited with error code.
[2023-08-12 22:15:09] See "systemctl status php5.6-fpm.service" and "journalctl -xeu php5.6-fpm.service" for details.
[2023-08-12 22:15:09] invoke-rc.d: initscript php5.6-fpm, action "restart" failed.
[2023-08-12 22:15:09] × php5.6-fpm.service - The PHP 5.6 FastCGI Process Manager
[2023-08-12 22:15:09] Loaded: loaded (/lib/systemd/system/php5.6-fpm.service; enabled; vendor preset: enabled)
[2023-08-12 22:15:09] Active: failed (Result: exit-code) since Sat 2023-08-12 22:14:57 EEST; 13ms ago
[2023-08-12 22:15:09] Docs: man:php-fpm5.6(8)
[2023-08-12 22:15:09] Process: 332352 ExecStart=/usr/sbin/php-fpm5.6 --nodaemonize --fpm-config /etc/php/5.6/fpm/php-fpm.conf (code=exited, status=78)
[2023-08-12 22:15:09] Process: 332354 ExecStopPost=/usr/lib/php/php-fpm-socket-helper remove /run/php/php-fpm.sock /etc/php/5.6/fpm/pool.d/www.conf 56 (code=exited, status=0/SUCCESS)
[2023-08-12 22:15:09] Main PID: 332352 (code=exited, status=78)
[2023-08-12 22:15:09] CPU: 32ms
[2023-08-12 22:15:09] Aug 12 22:14:57 xxx.xxx.xxx.xxx systemd[1]: Starting The PHP 5.6 FastCGI Process Manager...
[2023-08-12 22:15:09] Aug 12 22:14:57 xxx.xxx.xxx.xxx php-fpm5.6[332352]: [12-Aug-2023 22:14:57] WARNING: Nothing matches the include pattern '/etc/php/5.6/fpm/pool.d/*.conf' from /etc/php/5.6/fpm/php-fpm.conf at line 15.
[2023-08-12 22:15:09] Aug 12 22:14:57 xxx.xxx.xxx.xxx php-fpm5.6[332352]: [12-Aug-2023 22:14:57] ERROR: No pool defined. at least one pool section must be specified in config file
[2023-08-12 22:15:09] Aug 12 22:14:57 xxx.xxx.xxx.xxx php-fpm5.6[332352]: [12-Aug-2023 22:14:57] ERROR: failed to post process the configuration
[2023-08-12 22:15:09] Aug 12 22:14:57 xxx.xxx.xxx.xxx php-fpm5.6[332352]: [12-Aug-2023 22:14:57] ERROR: FPM initialization failed
[2023-08-12 22:15:09] Aug 12 22:14:57 xxx.xxx.xxx.xxx systemd[1]: php5.6-fpm.service: Main process exited, code=exited, status=78/CONFIG
[2023-08-12 22:15:09] Aug 12 22:14:57 xxx.xxx.xxx.xxx systemd[1]: php5.6-fpm.service: Failed with result 'exit-code'.
[2023-08-12 22:15:09] Aug 12 22:14:57 xxx.xxx.xxx.xxx systemd[1]: Failed to start The PHP 5.6 FastCGI Process Manager.
[2023-08-12 22:15:09] dpkg: error processing package php5.6-fpm (--configure):
[2023-08-12 22:15:09] installed php5.6-fpm package post-installation script subprocess returned error exit status 1
[2023-08-12 22:15:09] Setting up php7.2-fpm (7.2.34-39+ubuntu22.04.1+deb.sury.org+1) ...
[2023-08-12 22:15:09] NOTICE: Not enabling PHP 7.2 FPM by default.
[2023-08-12 22:15:09] NOTICE: To enable PHP 7.2 FPM in Apache2 do:
[2023-08-12 22:15:09] NOTICE: a2enconf php7.2-fpm
[2023-08-12 22:15:09] Job for php7.2-fpm.service failed because the control process exited with error code.
[2023-08-12 22:15:09] See "systemctl status php7.2-fpm.service" and "journalctl -xeu php7.2-fpm.service" for details.
[2023-08-12 22:15:09] invoke-rc.d: initscript php7.2-fpm, action "restart" failed.
[2023-08-12 22:15:09] × php7.2-fpm.service - The PHP 7.2 FastCGI Process Manager
[2023-08-12 22:15:09] Loaded: loaded (/lib/systemd/system/php7.2-fpm.service; enabled; vendor preset: enabled)
[2023-08-12 22:15:09] Active: failed (Result: exit-code) since Sat 2023-08-12 22:14:59 EEST; 6ms ago
[2023-08-12 22:15:09] Docs: man:php-fpm7.2(8)
[2023-08-12 22:15:09] Process: 333642 ExecStart=/usr/sbin/php-fpm7.2 --nodaemonize --fpm-config /etc/php/7.2/fpm/php-fpm.conf (code=exited, status=78)
[2023-08-12 22:15:09] Process: 333643 ExecStopPost=/usr/lib/php/php-fpm-socket-helper remove /run/php/php-fpm.sock /etc/php/7.2/fpm/pool.d/www.conf 72 (code=exited, status=0/SUCCESS)
[2023-08-12 22:15:09] Main PID: 333642 (code=exited, status=78)
[2023-08-12 22:15:09] CPU: 28ms
[2023-08-12 22:15:09] Aug 12 22:14:59 xxx.xxx.xxx.xxx systemd[1]: Starting The PHP 7.2 FastCGI Process Manager...
[2023-08-12 22:15:09] Aug 12 22:14:59 xxx.xxx.xxx.xxx php-fpm7.2[333642]: [12-Aug-2023 22:14:59] WARNING: Nothing matches the include pattern '/etc/php/7.2/fpm/pool.d/*.conf' from /etc/php/7.2/fpm/php-fpm.conf at line 125.
[2023-08-12 22:15:09] Aug 12 22:14:59 xxx.xxx.xxx.xxx php-fpm7.2[333642]: [12-Aug-2023 22:14:59] ERROR: No pool defined. at least one pool section must be specified in config file
[2023-08-12 22:15:09] Aug 12 22:14:59 xxx.xxx.xxx.xxx php-fpm7.2[333642]: [12-Aug-2023 22:14:59] ERROR: failed to post process the configuration
[2023-08-12 22:15:09] Aug 12 22:14:59 xxx.xxx.xxx.xxx php-fpm7.2[333642]: [12-Aug-2023 22:14:59] ERROR: FPM initialization failed
[2023-08-12 22:15:09] Aug 12 22:14:59 xxx.xxx.xxx.xxx systemd[1]: php7.2-fpm.service: Main process exited, code=exited, status=78/CONFIG
[2023-08-12 22:15:09] Aug 12 22:14:59 xxx.xxx.xxx.xxx systemd[1]: php7.2-fpm.service: Failed with result 'exit-code'.
[2023-08-12 22:15:09] Aug 12 22:14:59 xxx.xxx.xxx.xxx systemd[1]: Failed to start The PHP 7.2 FastCGI Process Manager.
[2023-08-12 22:15:09] dpkg: error processing package php7.2-fpm (--configure):
[2023-08-12 22:15:09] installed php7.2-fpm package post-installation script subprocess returned error exit status 1
[2023-08-12 22:15:09] No apport report written because MaxReports is reached already
[2023-08-12 22:15:09] Setting up php7.1-fpm (7.1.33-53+ubuntu22.04.1+deb.sury.org+1) ...
[2023-08-12 22:15:09] NOTICE: Not enabling PHP 7.1 FPM by default.
[2023-08-12 22:15:09] NOTICE: To enable PHP 7.1 FPM in Apache2 do:
[2023-08-12 22:15:09] NOTICE: a2enconf php7.1-fpm
[2023-08-12 22:15:09] Job for php7.1-fpm.service failed because the control process exited with error code.
[2023-08-12 22:15:09] See "systemctl status php7.1-fpm.service" and "journalctl -xeu php7.1-fpm.service" for details.
[2023-08-12 22:15:09] invoke-rc.d: initscript php7.1-fpm, action "restart" failed.
[2023-08-12 22:15:09] × php7.1-fpm.service - The PHP 7.1 FastCGI Process Manager
[2023-08-12 22:15:09] Loaded: loaded (/lib/systemd/system/php7.1-fpm.service; enabled; vendor preset: enabled)
[2023-08-12 22:15:09] Active: failed (Result: exit-code) since Sat 2023-08-12 22:15:04 EEST; 6ms ago
[2023-08-12 22:15:09] Docs: man:php-fpm7.1(8)
[2023-08-12 22:15:09] Process: 334968 ExecStart=/usr/sbin/php-fpm7.1 --nodaemonize --fpm-config /etc/php/7.1/fpm/php-fpm.conf (code=exited, status=78)
[2023-08-12 22:15:09] Process: 334969 ExecStopPost=/usr/lib/php/php-fpm-socket-helper remove /run/php/php-fpm.sock /etc/php/7.1/fpm/pool.d/www.conf 71 (code=exited, status=0/SUCCESS)
[2023-08-12 22:15:09] Main PID: 334968 (code=exited, status=78)
[2023-08-12 22:15:09] CPU: 40ms
[2023-08-12 22:15:09] Aug 12 22:15:04 xxx.xxx.xxx.xxx systemd[1]: Starting The PHP 7.1 FastCGI Process Manager...
[2023-08-12 22:15:09] Aug 12 22:15:04 xxx.xxx.xxx.xxx php-fpm7.1[334968]: [12-Aug-2023 22:15:04] WARNING: Nothing matches the include pattern '/etc/php/7.1/fpm/pool.d/*.conf' from /etc/php/7.1/fpm/php-fpm.conf at line 125.
[2023-08-12 22:15:09] Aug 12 22:15:04 xxx.xxx.xxx.xxx php-fpm7.1[334968]: [12-Aug-2023 22:15:04] ERROR: No pool defined. at least one pool section must be specified in config file
[2023-08-12 22:15:09] Aug 12 22:15:04 xxx.xxx.xxx.xxx php-fpm7.1[334968]: [12-Aug-2023 22:15:04] ERROR: failed to post process the configuration
[2023-08-12 22:15:09] Aug 12 22:15:04 xxx.xxx.xxx.xxx php-fpm7.1[334968]: [12-Aug-2023 22:15:04] ERROR: FPM initialization failed
[2023-08-12 22:15:09] Aug 12 22:15:04 xxx.xxx.xxx.xxx systemd[1]: php7.1-fpm.service: Main process exited, code=exited, status=78/CONFIG
[2023-08-12 22:15:09] Aug 12 22:15:04 xxx.xxx.xxx.xxx systemd[1]: php7.1-fpm.service: Failed with result 'exit-code'.
[2023-08-12 22:15:09] Aug 12 22:15:04 xxx.xxx.xxx.xxx systemd[1]: Failed to start The PHP 7.1 FastCGI Process Manager.
[2023-08-12 22:15:09] dpkg: error processing package php7.1-fpm (--configure):
[2023-08-12 22:15:09] installed php7.1-fpm package post-installation script subprocess returned error exit status 1
[2023-08-12 22:15:09] Setting up php7.0-fpm (7.0.33-66+ubuntu22.04.1+deb.sury.org+1) ...
[2023-08-12 22:15:09] NOTICE: Not enabling PHP 7.0 FPM by default.
[2023-08-12 22:15:09] NOTICE: To enable PHP 7.0 FPM in Apache2 do:
[2023-08-12 22:15:09] NOTICE: a2enconf php7.0-fpm
[2023-08-12 22:15:09] Job for php7.0-fpm.service failed because the control process exited with error code.
[2023-08-12 22:15:09] See "systemctl status php7.0-fpm.service" and "journalctl -xeu php7.0-fpm.service" for details.
[2023-08-12 22:15:09] invoke-rc.d: initscript php7.0-fpm, action "restart" failed.
[2023-08-12 22:15:09] × php7.0-fpm.service - The PHP 7.0 FastCGI Process Manager
[2023-08-12 22:15:09] Loaded: loaded (/lib/systemd/system/php7.0-fpm.service; enabled; vendor preset: enabled)
[2023-08-12 22:15:09] Active: failed (Result: exit-code) since Sat 2023-08-12 22:15:07 EEST; 6ms ago
[2023-08-12 22:15:09] Docs: man:php-fpm7.0(8)
[2023-08-12 22:15:09] Process: 336262 ExecStart=/usr/sbin/php-fpm7.0 --nodaemonize --fpm-config /etc/php/7.0/fpm/php-fpm.conf (code=exited, status=78)
[2023-08-12 22:15:09] Process: 336263 ExecStopPost=/usr/lib/php/php-fpm-socket-helper remove /run/php/php-fpm.sock /etc/php/7.0/fpm/pool.d/www.conf 70 (code=exited, status=0/SUCCESS)
[2023-08-12 22:15:09] Main PID: 336262 (code=exited, status=78)
[2023-08-12 22:15:09] Aug 12 22:15:07 xxx.xxx.xxx.xxx systemd[1]: Starting The PHP 7.0 FastCGI Process Manager...
[2023-08-12 22:15:09] Aug 12 22:15:07 xxx.xxx.xxx.xxx php-fpm7.0[336262]: [12-Aug-2023 22:15:07] WARNING: Nothing matches the include pattern '/etc/php/7.0/fpm/pool.d/*.conf' from /etc/php/7.0/fpm/php-fpm.conf at line 125.
[2023-08-12 22:15:09] Aug 12 22:15:07 xxx.xxx.xxx.xxx php-fpm7.0[336262]: [12-Aug-2023 22:15:07] ERROR: No pool defined. at least one pool section must be specified in config file
[2023-08-12 22:15:09] Aug 12 22:15:07 xxx.xxx.xxx.xxx php-fpm7.0[336262]: [12-Aug-2023 22:15:07] ERROR: failed to post process the configuration
[2023-08-12 22:15:09] Aug 12 22:15:07 xxx.xxx.xxx.xxx php-fpm7.0[336262]: [12-Aug-2023 22:15:07] ERROR: FPM initialization failed
[2023-08-12 22:15:09] Aug 12 22:15:07 xxx.xxx.xxx.xxx systemd[1]: php7.0-fpm.service: Main process exited, code=exited, status=78/CONFIG
[2023-08-12 22:15:09] Aug 12 22:15:07 xxx.xxx.xxx.xxx systemd[1]: php7.0-fpm.service: Failed with result 'exit-code'.
[2023-08-12 22:15:09] Aug 12 22:15:07 xxx.xxx.xxx.xxx systemd[1]: Failed to start The PHP 7.0 FastCGI Process Manager.
[2023-08-12 22:15:09] dpkg: error processing package php7.0-fpm (--configure):
[2023-08-12 22:15:09] installed php7.0-fpm package post-installation script subprocess returned error exit status 1
[2023-08-12 22:15:09] Errors were encountered while processing:
[2023-08-12 22:15:09] php7.3-fpm
[2023-08-12 22:15:09] php5.6-fpm
[2023-08-12 22:15:09] php7.2-fpm
[2023-08-12 22:15:09] php7.1-fpm
[2023-08-12 22:15:09] php7.0-fpm
[2023-08-12 22:15:09] needrestart is being skipped since dpkg has failed
[2023-08-12 22:15:09] E: Sub-process /usr/bin/dpkg returned an error code (1)
[2023-08-12 22:15:10] Get:1 https://packages.panopta.com:443/deb stable InRelease [7323 B]
[2023-08-12 22:15:10] Hit:2 http://fr.archive.ubuntu.com/ubuntu jammy InRelease
[2023-08-12 22:15:10] Hit:3 https://ppa.launchpadcontent.net/ondrej/php/ubuntu jammy InRelease
[2023-08-12 22:15:10] Hit:4 http://fr.archive.ubuntu.com/ubuntu jammy-updates InRelease
[2023-08-12 22:15:10] Hit:5 http://fr.archive.ubuntu.com/ubuntu jammy-security InRelease
[2023-08-12 22:15:10] Ign:6 http://rpms.litespeedtech.com/debian jammy InRelease
[2023-08-12 22:15:10] Get:7 http://rpms.litespeedtech.com/debian jammy Release [3134 B]
[2023-08-12 22:15:10] Ign:8 https://download.webmin.com/download/newkey/repository stable InRelease
[2023-08-12 22:15:10] Hit:9 https://repo.imunify360.cloudlinux.com/imunify360/ubuntu/22.04 jammy InRelease
[2023-08-12 22:15:10] Hit:10 https://download.imunify360.com/ubuntu/22.04/slot-1 jammy InRelease
[2023-08-12 22:15:10] Hit:11 https://download.imunify360.com/ubuntu/22.04/slot-2 jammy InRelease
[2023-08-12 22:15:10] Get:12 https://download.webmin.com/download/newkey/repository stable Release [16.0 kB]
[2023-08-12 22:15:11] Hit:13 https://download.imunify360.com/ubuntu/22.04/slot-3 jammy InRelease
[2023-08-12 22:15:11] Get:14 https://download.webmin.com/download/newkey/repository stable Release.gpg [819 B]
[2023-08-12 22:15:11] Hit:15 https://download.imunify360.com/ubuntu/22.04/slot-4 jammy InRelease
[2023-08-12 22:15:11] Hit:17 https://download.imunify360.com/ubuntu/22.04/slot-5 jammy InRelease
[2023-08-12 22:15:11] Hit:18 https://download.imunify360.com/ubuntu/22.04/slot-6 jammy InRelease
[2023-08-12 22:15:11] Hit:19 https://download.imunify360.com/ubuntu/22.04/slot-7 jammy InRelease
[2023-08-12 22:15:11] Hit:20 https://download.imunify360.com/ubuntu/22.04/slot-8 jammy InRelease
[2023-08-12 22:15:12] Ign:14 https://download.webmin.com/download/newkey/repository stable Release.gpg
[2023-08-12 22:15:14] Reading package lists...
[2023-08-12 22:15:14] W: http://packages.panopta.com/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
[2023-08-12 22:15:14] W: GPG error: https://download.webmin.com/download/newkey/repository stable Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2D223B918916F2A2
[2023-08-12 22:15:14] E: The repository 'https://download.webmin.com/download/newkey/repository stable Release' is not signed.
[2023-08-12 22:15:14] apt-get update error.
root@154:~#
Knowing that all websites on the server are working normally
