Important Announcement for people with Upgrade Issues
Hello Everyone.
Moving forward use upgrade from Cloud to avoid any issues during upgrade → https://cyberpanel.net/docs/how-to-upgrade-your-cyberpanel-using-cyberpanel-cloud/
For people with issues related to upgrade. (Mostly related to emails).
You can contact us through → https://cloud.cyberpanel.net/
And do mention that your email services stopped working after upgrade. We will then enable Cloud Email Debugger in your account, using which you can reset your email configurations to default. It will also check and fix all SSL related issues on your email server.
Have a good day.
The problem with upgrading to Cloud is the future Fee worth $30/month but the current CyberPanel is Free. I hope you just fix the issue in CyberPanel and not force us to Pay more than the cPanel.
@AlonaG not true, we’ve mentioned this in the article if you bother reading.
Note: This is free for everyone.
Connecting server to CP Cloud and using upgrade feature is free along with the MySQL optimization feature.
Kindly spend some time reading this article → https://cyberpanel.net/docs/how-to-upgrade-your-cyberpanel-using-cyberpanel-cloud/
Thanks for your reply but this link said it is $30/mo. https://cyberpanel.net/cyberpanel-cloud-pricing/. Will the Cloud be free forever? Actually, I don’t mind if you charge a little in CyberPanel like $1.5/mo. but make sure it work.
@AlonaG
I would say again that CONNECT AND UPGRADE + MYSQL OPTIMIZATION is free from cloud.
Its not even $1.5. Go ahead and connect your server to cloud and upgrade if it even ask you for 30 cents then you can come back and complain here.
Hello @usmannasir
I made the connection and it’s successful. Upgrade has some issues. After I choose 2.1.1 and click on the upgrade now it gives me an error without any description.
What can I do to upgrade?
Thanks
Best regards
Roonin
Hi again. Well, I missed the following text out :slight_smile:
After v2.1.1 and above we‘ve added an option in the cloud to perform fail-safe upgrade. (This works only if you are on v2.1.1 or above)
I’m on 2.0.3.
Ok. How can I upgrade it to 2.1.1? Is there any tutorial for this? I couldn’t find any.
thanks again.
Hi again. Please do not ban me because of spammy comments. :slight_smile:
I find a way on how to upgrade it via ssh.
Thank you again.
Best Regards
Roonin
Hi there!
I have connected there and tried update, but i go onli a empty pink error on the bottom of that page. I did the upgrade by myself and had some issues, like pdns, postfix and dovecot dont starting after restart. Even after enable all those services that don’t worked. So i fixed the permissions on /etc/pdns/pdns.conf and now i’m starting each time the restart is need, just will wait some hours to see if the services will keeep alive.
I have started a new machine and it’s on 2.0.3.
when i tried to upgrade with Cyberpanel cloud, it’s giving an error when I select 2.1.1 in the upgrade section. How can 2.0.3 users upgrade to 2.1.1? Please guide. TIA
For v2.0.3, use the old upgrade method
Please add support for Ubutnu 21.04
V2.1.1-dev does not work on the cloud yet from what I’ve seen.
They’re pushing everyone they can to paid support.
This panel is probably going to become closed source, greedy SaaS.
@usmannasir
Just used the FREE MYSQL OPTIMIZATION… Now my server returns error 500 and unable tp start Maria DB. WTF!!!
@RandomFandomOfficial yes this explains why I never get a reply to any of my support requests
Hello Sir I need one Help My Website getting mkdr permission in Codeignator i try all things I add all permissions but same issue i get please help how to solved this issue in cyberpanel
See backend screenshot
See frontend issue
I can’t change cyberpanel password at lastest version.
i don’t find it
Sunddenly My all site not working.
Can’t new wp install
Can’t active/ deactive any plugins.
can’t add new post
After upgrading, you must specify when emails the Admin has stopped working. We will then add the Cloud Email Debugger to your account using the ability to convert email design backward. This checks and corrects all SSL settings for your email account.
Type your commentCan anyone help me, site just doesn’t run.
4GB 2 core VPS with 7 cent.
I installed cloud.cyberpanel and wordpress, the site with a native theme just doesn’t run.
