I am not able to login to ImmunifyAV. The screenshot below is the immunifyAv login page showing:
Yes I have the same problem after update. Any idea ho to resolve?
can you please just update your cyberpanel once and also tell me if you installed the imunify360 before installing imunifyav on the server?
thanks for reply. I resolv problem by install again IMUNIFYAV in cli.
