ImmunifyAV installation failed | Help required
Hello all,
I updated my CyberPanel instance a few days ago using the Install/Upgrade command since the panel was not up to date. Once the upgrade was successful, I happened to notice the ImmunifyAV component in the Security section of CyberPanel admin interface and clicked on it to check it out and possibly install it.
Since it looked like a convincing plugin, I clicked on install now and I am not sure what exactly happened, nor do I have the log saved but it seemed like the installation had failed. I refreshed the page to make sure that was the case and was faced with an access now button which when I clicked displayed not found error
Could someone kindly guide me on how install this plugin manually or possibly reinstall it through the dashboard
Thank you
Can you please give me your OS details also
reinstall imunify once from the terminal and check
Thank you for your response.
I am running Ubuntu 20.04.3 LTS [5.4.0-96-generic]
I am not sure how to do this, could you kindly share the command or a guide
sometimes i need the docs too
@shoaibkk @die2mrw007 we lack of updated docs and documented troubleshoting
Just figured out how to install ImmunifyAV on CyberPanel if the installation through the dashboard failed but you are seeing the ‘Access Now’ button and get redirected to a page which says, ‘Not Found’, ‘The requested resource was not found on this server’
Thanks to @PowerChaos for sharing the ImmunifyAV manual installation guide ( ImunifyAV for cPanel and DirectAdmin | Documentation)
