I need to use nginx on the CyberPanel
Hi, I want to use Cyberpanel to host my wordpress site and peertube. I wonder if I can install Nginx on this server, which also runs Cyberpanel?
I am new to set up servers. I search Cyberpanel docs as well as this forum. Haven’t find any related topics.
I tried to install nginx, but it failed:
sudo systemctl status nginx
× nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2023-09-09 00:30:45 UTC; 10s ago
Docs: man:nginx(8)
Process: 138359 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 138360 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=1/FAILURE)
CPU: 9ms
Sep 09 00:30:43 localhost systemd[1]: Starting A high performance web server and a reverse proxy server…
Sep 09 00:30:43 localhost nginx[138360]: nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Unknown error)
Sep 09 00:30:44 localhost nginx[138360]: nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Unknown error)
Sep 09 00:30:45 localhost nginx[138360]: nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Unknown error)
Sep 09 00:30:45 localhost nginx[138360]: nginx: [emerg] still could not bind()
Sep 09 00:30:45 localhost systemd[1]: nginx.service: Control process exited, code=exited, status=1/FAILURE
Sep 09 00:30:45 localhost systemd[1]: nginx.service: Failed with result ‘exit-code’.
Sep 09 00:30:45 localhost systemd[1]: Failed to start A high performance web server and a reverse proxy server.
Here is information about my server:
  • Post your server os version : Ubuntu 22.04 LTS
  • Post the details of my cyberpanel version:
Current Version:
2.3
Build:
4
Current Commit:
d65b6b5bcd4e89ce1a0eeb74131f98093e85bb3a
Latest Version:
2.3
Latest Build:
4
Latest Commit:
you must configure nginx to a different port than 80 and reverse proxy litespeed/ols to nginx port
Thanks for your tips.
Other than configure a different port, what else do I need to do? Do I need to do anything for the peertube, the website use Nginx?
Yes, your website uses nginx as backend and ols as frontend
What is ols? :cowboy_hat_face:
OpenLiteSpeed
I searched online about how to
It almost all mentioned:
server {
listen 80 default_server;
listen [::]:80 default_server;
But when I run ‘vi /etc/nginx/nginx.conf’
There is no such line in this file.
#mail {
# See sample authentication script at:
# Using a PHP Script on an Apache Server as the IMAP Auth Backend | NGINX
# auth_http localhost/auth.php;
# pop3_capabilities “TOP” “USER”;
# imap_capabilities “IMAP4rev1” “UIDPLUS”;
server {
listen localhost:110;
protocol pop3;
proxy on;
server {
listen localhost:143;
protocol imap;
proxy on;
Do I simply add those lines in?
I am really new to self-hosting. Can anyone please tell me how can I config Nginx on CyberPanel?
Thanks in advance.
