Although it is possible yes, just don’t.
Update your script/website.
Using old versions is opening the door to exploits and bugs.
So, don’t.
I’m not able to update the script because its not my script…I buy the script from another vendor which support maximum of php version 7.1…So, it is not on my hand…if there is any method in cyberpanel then please guide me.
If you bought it, then tell the person to update it.
Show him this:
https://www.php.net/supported-versions.php
https://www.php.net/eol.php
Or wait for someone to guide you.
I know what you are trying to say…but this script is bor cloaking and it only works on below 7.1…show only way is to install on php version 7.1 or low…otherwise it not works.
Downgrade to ubuntu 18, have fun with php 7.0
If you can find script what do same job with PHP8 support dump that script. If developer of paid product still on 7.1 run away…
You can try the following steps to install PHP 7.1 on your Ubuntu 20.04 server manually
Install PHP 7.1 and Required Extensions…
sudo apt install php7.1 php7.1-common php7.1-cli php7.1-fpm php7.1-mysql php7.1-curl php7.1-json php7.1-gd php7.1-mbstring php7.1-xml php7.1-zip
Switch to PHP 7.1.
sudo update-alternatives --set php /usr/bin/php7.1
sudo update-alternatives --set phar /usr/bin/phar7.1
sudo update-alternatives --set phar.phar /usr/bin/phar.phar7.1
Restart PHP-FPM.
sudo systemctl restart php7.1-fpm
Now verify you PHP Version php -v or you can upgrade your application on php 8. It’s recommended.
I hope it helps.
