I cannot see max Disk Usage in cyberpanel on my vps
I am currently using Cyberpanel free version on my vps. My vps has been set
  • 300gb hard disk
  • 16gb Memory
  • and 8 core cpu
But when login on my VPS, it show
Current Server time : 2019-10-11 08:21:30.
Current Load average: 0.10, 0.17, 0.13
Current CPU usage : 0.372632%.
Current RAM usage : 642/15884MB (4.04%).
Current Disk usage : 5/50GB (11%).
System uptime : 1 days, 23 hours, 1 minutes.
Enjoy your accelerated Internet by CyberPanel.
-bash: warning: setlocale: LC_CTYPE: cannot change locale (UTF-8): No such file or directory
I don’t know why current disk usage is 50gb. My hard disk set on vps is 300gb.
Try df -h command:
Filesystem Size Used Avail Use% Mounted on
devtmpfs 16G 0 16G 0% /dev
tmpfs 16G 41M 16G 1% /dev/shm
tmpfs 16G 138M 16G 1% /run
tmpfs 16G 0 16G 0% /sys/fs/cgroup
/dev/mapper/centos-root 50G 5.1G 45G 11% /
/dev/sda1 1014M 188M 827M 19% /boot
/dev/loop0 1.5G 18M 1.4G 2% /tmp
/dev/mapper/centos-home 241G 3.0G 239G 2% /home
tmpfs 3.2G 0 3.2G 0% /run/user/0
Can anyone help me understand and fix this issue?
This will give you a breakdown of home
du -h /home/ | grep ^[0-9.]*G
Breakdown of everything
du -h / | grep ^[0-9.]*G
It’s confusing as there are multiple partitions and the /root partition shows its 50G in size but only 5.1G of that is used. “5/50GB (11%).” Most likely that is due to the core OS.
You still got tons of space it’s just across all those temp partitions and /home
The cyberpanel welcome thing is only reporting the disk space/use for the / root partition so it seems like its missing stuff but it’s all there :slight_smile:
Oh, thank you.
So I just need to leave it there and not need to do anything
yeah its all totally ok. It just looks confusing with your partition layout.
A lot of VPS servers have a single partition on / so they can autogrow the disk for upgrades. The script currently only checks the / partition maybe we can look into taking other partitions into account in the future.
Good day
I am new to cyberpanel and just installed on a dedicated server, but I have the same problem as the friend above, how can I solve it since it only marks 50GB available to use.
I appreciate your help and attention.
[root@server ~]# df -h
S.ficheros Tamaño Usados Disp Uso% Montado en
devtmpfs 7.6G 0 7.6G 0% /dev
tmpfs 7.6G 105M 7.5G 2% /dev/shm
tmpfs 7.6G 9.1M 7.6G 1% /run
tmpfs 7.6G 0 7.6G 0% /sys/fs/cgroup
/dev/mapper/centos-root 50G 7.8G 43G 16% /
/dev/mapper/centos-home 1.8T 33M 1.8T 1% /home
/dev/sda2 1014M 186M 829M 19% /boot
/dev/sda1 200M 12M 189M 6% /boot/efi
tmpfs 1.6G 0 1.6G 0% /run/user/0
