ClosedI cannot find Fail2ban system monitor on the admin dashboard
Happy New Year @rssperky
CyberPanel does not offer fail2ban by default on the admin dashboard.
You can install configserver and access it from https://SERVER_URL:8090/configservercsf/ and you can ban ip addresses temporarily or permanently at the comfort of your admin dashboard
You can always install fail2ban manually on your server and protect your server your own way
I recommend crowdsec participative IPS and solution as best alternative for fail2ban.
Thank you for fast reply. What is “crowdsec participative IPS”?
See their website https://www.crowdsec.net/
This seems very fine, only install on server? Won’t it collide with CyberPanel?
No conflict. I can confirm that through this repo https://github.com/josephgodwinkimani/cyberpanel
Just install it the way the state in the documentation on your current installation
I installed, thank you!!!
