If I try to send an email using rainloop, It does not make into inbox nor spam.
If someone sends an email to me, I can read that email in rainloop inbox, but even if I reply to that email. Other user cannot see the reply.
Basically, I am receiving emails but not able to send back.
I did a mistake and made an email in mail.domain.com instead of domain.com while creating email. Now I am unable to delete it. Can that be the reason for it ?
Also, If I try to use POP3 and connect with gmail, I get error “Cannot connect to mail.domain.com”
Sorry For late Reply! I will try to be quick next time.
Here is the log you must be looking for!
May 04 00:09:32 ip-172-31-32-67 postfix/submission/smtpd[118262]: connect from localhost[127.0.0.1]
May 04 00:09:32 ip-172-31-32-67 postfix/submission/smtpd[118262]: TLS SNI localhost from localhost[127.0.0.1] not matched, using default chain
May 04 00:09:32 ip-172-31-32-67 postfix/submission/smtpd[118262]: C13CF7F895: client=localhost[127.0.0.1], sasl_method=PLAIN, sasl_username=talhasenpai@neosells.com
May 04 00:09:32 ip-172-31-32-67 postfix/submission/smtpd[118262]: warning: connect to /var/log/policyServerSocket: No such file or directory
May 04 00:09:33 ip-172-31-32-67 postfix/submission/smtpd[118262]: warning: connect to /var/log/policyServerSocket: No such file or directory
May 04 00:09:33 ip-172-31-32-67 postfix/submission/smtpd[118262]: warning: problem talking to server /var/log/policyServerSocket: No such file or directory
May 04 00:09:33 ip-172-31-32-67 postfix/cleanup[118265]: C13CF7F895: message-id=85df8a04cfeea5dadbf13890c2093d09@neosells.com
May 04 00:09:33 ip-172-31-32-67 postfix/qmgr[87181]: C13CF7F895: from=talhasenpai@neosells.com, size=1305, nrcpt=1 (queue active)
May 04 00:09:33 ip-172-31-32-67 postfix/submission/smtpd[118262]: disconnect from localhost[127.0.0.1] ehlo=2 starttls=1 auth=1 mail=1 rcpt=1 data=1 quit=1 commands=8
May 04 00:09:33 ip-172-31-32-67 postfix/smtp[118268]: connect to gmail-smtp-in.l.google.com[2404:6800:4003:c00::1b]:25: Network is unreachable
May 04 00:10:03 ip-172-31-32-67 postfix/smtp[118268]: connect to gmail-smtp-in.l.google.com[74.125.200.26]:25: Connection timed out
Most of the providers block the SMTP ports. I was able to work around it by using SENDGRId and integrating it. It works just fine now bit of a hassle to open an account on sendgrid everytime i open a new domain, but nothing we can do unless the hosts fix it.
wow! I’m happy to hear you found a fix
I will look into Sendgrid if AwS doesn’t resolve the issue for me …
Thanks allot for letting me know. I had no idea about an alternate way
