First of all thank you for this great and amazing product!.
I am truly impressed!!!
Found only one problem:
The htaccess file, when adding rewrite rules insurrections does not work
at least not in my language (hebrew) or any other UTF-8 languages
for example, if I add this:
RewriteCond %{QUERY_STRING} a=work
RewriteCond %{QUERY_STRING} x=300
RewriteRule ^$ /טכנאים-ברמת-גן/? [L,R=301]
after saving a few time the Hebrew changes to a different words!!
and by that mess all the redirect
example of the new words after you save and reopen it could be
RewriteRule ^$ /טכנ-בגמת-ג/? [L,R=301]
which is of course page which does not exist, therefor this a critical issue.
I thought about saving the htaccess as UTF-8 instead of ASCII
I think I tried it, and still the htaccess messes the words
another issue is that if you put Hebrew in the query it will not work at all.
i.e
RewriteCond %{QUERY_STRING} worker=משה-טכנאים
RewriteRule ^$ /index/משה-טכנאים/? [L,R=301]
By the way, you can see that there is a problem, because even if you create a new fresh website . the hebrew letters in the new file are just wrong and create gibberish instead of Hebrew instructions which was meant to be
Here are the strange Hebrew instructions found in a new htaccess file.
BEGIN WordPress
הראות (שורות) בין “BEGIN WordPress” לבין “END WordPress” הן
נוצר באן דינמי, ויש לשנו אותן רק באמצעות יטרים של וורדפר.
ל שינוי בהוראת בין סממנים אלה דרס.
So this is a defiantly a bug, since the htaccess can not handle Hebrew font.
Thank you
