Good day! Please I need Help
I know this discussion is a bit stale, but since it’s the only one I found while searching - it’s possible this is what others get to see.
I tried the above method but it isn’t working for me. I found that using RewriteRule ^/?listing/(.*)$ https://www.def.com/listing/$1 [R=301,L] is more correct with openlitespeed from here Migrate Apache Rewrite Rules to OpenLiteSpeed Web Server
Unfortunately, redirect still isn’t working. What am I missing? The main Site is MU subdomain
I know this discussion is a bit stale, but since it's the only one I found while searching - it's possible this is what others get to see.
I tried the above method but it isn't working for me. I found that using RewriteRule ^/?listing/(.*)$ https://www.def.com/listing/$1 [R=301,L] is more correct with openlitespeed from here
https://openlitespeed.org/kb/migrate-apache-rewrite-rules-to-openlitespeed/
It seems I was a bit hasty, It’s working now - flawlessly. (Seems I needed to restart Litespeed)
After a big time I took a Redirect error again. I solved my problem with Hostephen’s advice and I want to update for others that taking error. As Hostephen said now this is working with a bit change for me. Anyone can try this three forms.
I haven’t make this work in an .hatcess file (inside public_html folder, wordpress)
Also. Can the redirection be to an external URL? As usual? Because I’m sort of pissed of this isn’t working. So many hours with this, and yet here we are…
