I am not sure we are able to protect custom port with password authentication. To protect OLS webadmin console, you can change your default port and we hope at next release CyberPanel have ability to change port because for right now CyberPanel couldn’t change default port because it is hard coded (means no config)
@gabrielwaskito Hi Thanks for your support. For OLS, I need to change port to 80 or 443 or 8080, 8043? Which file can I modify to change cyberpanel port? Thank you.
@rc112 said: @gabrielwaskito Hi Thanks for your support. For OLS, I need to change port to 80 or 443 or 8080, 8043? Which file can I modify to change cyberpanel port? Thank you.
I’d like to find out how to setup a password protected directory through CyberPanel. Able to provide a tutorial? I would like to have folders password protected (not reliable on any type of database/mysql/etc).
