htaccess not writable?
I installed LSCache, but when setting = there was an error ERROR 9042: .htaccess file not writable.
Please add / replace the codes into the beginning of /home/xxx.com/public_html/.htaccess:
but when I use the wp fastest cache plugin, I was never told that htaccess is not writable, and there is no information about htaccess code text.
There is only a description of “Options have been saved”. But actually code is not entered in the .htaccess file. so you can manually copy and paste on htaccess?
then how can htaccess be writable?
