hi ,
i love “cyberpanel” <3 it’s amazing work
thank you to keep it for free .
my problem with rewrite rules , i followed the instruction here “6 - Rewrite Rules - 04 - Websites - CyberPanel Community”
but all time’s i get 404 when try access to →
Website Domain Names, Online Stores & Hosting - Domain.com
domain.com/en/call_us
can you help me please ? ![]()
.htaccess file in attachments
@mrjk990 said:
hi ,
i love “cyberpanel” <3 it’s amazing workthank you to keep it for free .
my problem with rewrite rules , i followed the instruction here “http://docs.cyberpanel.net/doku.php?id=rewrite-rules”
domain.com/en
Hello @mrjk990
Thank you for your feedback, we appreciate.
I’ve made some adjustments to your rewrite rules, let me know if you still have issues.
RewriteRule ^([a-z]{2})/?(.)$ index.php/$2?flag=$1 [L,QSA] >> RewriteRule ^/([a-z]{2})/?(.)$ index.php/$2?flag=$1 [L,QSA]
There is an additional slash.
For more information about rewrite syntax with Openlitespeed you can read: http://open.litespeedtech.com/mediawiki/index.php/Help:Rewrite_Rule_Differences
Best Regards
hi , thanks for your response ,
after test .htaccess not working on any site ,
even if .htaccess file contains an incorrect code!!
all time get 404
please help
Can you please create ticket here.
I will look into this, please attach necessary login details with your ticket and website address.
Best Regards.
Ticket Created <3 thanks
Hello, i got same problem could you check my htaccess and edit it to make it working?
Options -MultiViews
RewriteEngine On
RewriteBase /
RewriteRule \.(js|css|jpeg|jpg|gif|png|ico|map)(\?|$) /404error.php [L,NC]
RewriteRule . /index.php [L]
I get this error `404
Not Found
The resource requested could not be found on this server!`
Fixed
You can mention below for others to see that how you fixed your problem.
Correcting Error 404 not found
- Note:
it is not necessary to use .htaccess
Follow the steps below to fix the site access error (404 not found)
1- Log in to the cyberpanel
You must log in to the account of the site that you want to correct the error 404 not found
2- In the left side menu click on “Websites”. Now click on “List Websites”
3- Select the website
You should select the website by clicking the cyberpanel icon located in Launch (right side of the domain you want to fix the problem).
4- Accessing domain rules
Scroll down the page and click “Rewrite Rules” located in the “CONFIGURATIONS” area.
5 - Rewriting domain rules
Copy the code below and paste in the Rewrite Rules area, changing “http://www.domain.com” for your domain. Then click the “Save Rewrite Rules” button.
7 - Access your site using www
example:
www.domain.com
Hi, I have this .htaccess rules in my php script, but its not working. Its used to work in appache server. but its not in openlitespeed. My cyberpanel version is 1.8.
Options -MultiViews -IndexesRewriteEngine On
# Handle Authorization Header
RewriteCond %{HTTP:Authorization} .
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
# Redirect Trailing Slashes If Not A Folder...
RewriteCond %{REQUEST_URI} (.+)/$
RewriteRule ^ %1 [L,R=301]
# Handle Front Controller...
RewriteRule ^ index.php [L]
Someone help me out. Its always giving 404 error. see here at https://adkit.in
Hi, I have this .htaccess rules in my php script, but its not working. Its used to work in appache server. but its not in openlitespeed. My cyberpanel version is 1.8. Options -MultiViews -IndexesRewriteEngine On # Handle Authorization Header RewriteCond %{HTTP:Authorization} . RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}] # Redirect Trailing Slashes If Not A Folder... RewriteCond %{REQUEST_FILENAME} !-d RewriteCond %{REQUEST_URI} (.+)/$ RewriteRule ^ %1 [L,R=301] # Handle Front Controller... RewriteCond %{REQUEST_FILENAME} !-d RewriteCond %{REQUEST_FILENAME} !-f RewriteRule ^ index.php [L]Someone help me out. Its always giving 404 error. see here at https://adkit.in
That is the main reason I am requesting this https://forums.cyberpanel.net/discussion/1485/apache-as-backend to make sure we don’t have any issues with .htaccess after migrating apps to CyberPanel
No reply
If anyone needs full .htaccess support, that is what LiteSpeed Enterprise is for. You can read more at what is supported and not supported in OpenLiteSpeed here → https://cyberpanel.net/2018/09/10/openlitespeed-v1-4-38-has-been-released/
and @Chlitzxer you still have only very few votes.
