How to write translation for CyberPanel
Hello
To write translation for CyberPanel, you can download the language file from: https://raw.githubusercontent.com/usmannasir/cyberpanel/1.8.0/locale/br/LC_MESSAGES/django.po
msgid "Create Cloud Linux Package - CyberPanel"
msgstr "Add your translated text here"
Using this method replace all msgstr with your translated text. Once the file is completed, you can either create a pull request on Github, or email your translated file to support[at]cyberpanel.net. Make sure to include the name of the language you have translated to.
Thanks.
Hi
I have added updated Polish translation on github.
@Nencio added to the package.
The CyberPanel One-Click Image is a next-generation hosting control panel, language and type in your username and password to log in to CyberPanel
Please add a Polish language to the project, because I do not have any rights to the project on github.
Using this method replaces all msgstr with your translated text. Once the file is completed, you can either create a pull request on Github or email your translated file to support[at]cyberpanel.net. Make sure to include the name of the language you have translated to.
@CyberPanel I tried finding the English file in the stable GitHub.
Can’t find it.
I find all the other languages, but not the default English one.
I wanted to copy the English one, and translate it.
I don’t want to translate a language that I can’t really know if i translate correctly.
This manual is deprecated. Where is English is this folder ?
/usr/local/CyberCP/locale
I’m modify my language file, but after saving and restarting the server there are no changes in the interface
Hi, the github link is broken, for latest version its: cyberpanel/django.po at stable · usmannasir/cyberpanel · GitHub
