m76eef
August 27, 2020, 11:24pm
1
i am so new to cyberpanel, and i found it really amazing, but i dont know how to whitelist multi ip addresses, my website is a partner with ezoic ads, and they told my to whitelist their ip addresses to avoid origin error or 520 error,
check this article :
Ezoic .
there are around 1500 ip addresses to whitelist, and i dont know how to do it. can you help me please?
thanks
themew
August 28, 2020, 2:19pm
2
You can install CSF, which replaces the standard CyberPanel firewall and add as many whitelist/blacklist ip address as you require.
m76eef
August 28, 2020, 10:32pm
3
doest it accept ip ranges like this “x.x.x.x/x” ?
themew
August 28, 2020, 11:20pm
4
Yes. To block 192.168.0.0 to 192.168.0.255 you would add 192.168.0.0/24 to the blocked list.
m76eef
August 29, 2020, 10:52am
5
thank you so much!
Hi there. For the CSF install, did you simply do the steps outlined here, Using CSF with CyberPanel • NetWeaver .
Is there anything else required?
Also, out of curiosity, does it have an interface in CyberPanel?
