Hi there,
I’ve tried to set up subdomains, one for cyber.mydomain.com, and one for litespeed.mydomain.com.
Both successfully got an SSL certificate issued during site creation. But I was not able to get it to load on port 8090 (for Cyber, which is what I was working on first).
So then I followed instructions on Cyber website for this process, and used SSL > Hostname SSL.
It gave me the message I could now access control panel on https://mydomain.com:8090
It started working after that.
I tried the same thing for litespeed.mydomain.com, but now that domain is trying to load the cyber.mydomain.com SSL certificate (after doing the Hostname SSL process, on https://litespeed.mydomain.com.
So now I’m a bit stuck. What is the Hostname SSL process doing that sets things up for SSL on port 8090 for Cyber Panel? How would I change this (on command line) to get 7080 to work for my other subdomain?
Thanks
Jonathan
