Cloudflare only allows a handful of HTTP ports and HTTPS ports. That makes it impossible to access port 8090 (cyberpanel) or 7080 (Openlitespeed Webadmin) unless you go with their paid plan. Well here is a solution. Go to your cyberpanel (from your IP address) and click create a website. Enter a random subdomain (choose something complicated so that hackers have a harder chance to get to your panel page. Don’t choose panel.yourdomain.com) and click create. Go to your Cloudflare dashboard and point that subdomain to your IP address (making sure that the Proxy icon is turned to DNS only). Then go down to SSL < Hostname SSL and install a panel SSL.
Done.
Then instead of going to yourdomain.com:8090 or yourdomain.com:7080. You can go to subdomain.yourdomain.com:8090 or subdomain.yourdomain.com:8090. Then you can enjoy the benefits of the Cloudflare CDN and make your web panel secure.
