How to switching from LiteSpeed Enterprise Webserver to OpenLiteSpeed.
Thanks!
Thanks!
By re-installing the operating system and re-installing CyberPanel, you can use a separate server and move sites there.
Yup, thanks
is there any other way?
But you can backup all websites on your Enterprise installation and can reimport them in the OpenLitepeed installation. I just tested it, because I build aup a fallback server for my main installation
