I follow the installation steps but it does not work.
Is there anyone who can build a Phalcon?
which part it doesn’t work ?
The page does not load when I activate the plugin from “php.ini”.
For example, I installed and activated the plugin in PHP 7.3. My website does not open.
is your system centos or ubuntu ? what php version ?
CentOS. I tried it on PHP 7.1, 7.2 and 7.3.
Sorry forgot to ask , was it enterprise or openltiespeed?
Sorry forgot to ask , was it enterprise or openltiespeed?OpenLitespeed
I think it should be better you create a issue on their github , because I have failed to set it up on OLS, LSWS and PHP-FPM, all result in PHP crash.
dissertationwriter said: The page does not load when I activate the plugin from "php.ini". For example, I installed and activated the plugin in PHP 7.3. My website does not open.
Did you checkif you have a valid php.ini in your /cgi-bin?
