Hello.
TL;DR: I want to use the Imagify plugin to optimize images and generate webp (but not to show them), and the LiteSpeed plugin to show already generated webp images by Imagify (but not to generate/optimize).
I have been using the Imagify plugin to optimize images, generate WebP, and display them using the “replace” method (because the rewrite method doesn’t work for some reason).
The problem is that the “replace” method doesn’t work well in my theme anymore.
The LiteSpeed plugin has the option to display webp images using htaccess rewrite method and that works great. But, I do not want to use LiteSpeed to optimize images and generate webp.
So, I just want to use LiteSpeed to display webp versions (if exists), and Imagify to generate webp images.
Is something like that possible? Thanks
Ubuntu 20.04
Current Version: 2.3
Build: 2Current Commit: bb6d095a5362deccf8166759ce69d8576eafc7c7
Latest Version: 2.3
Latest Build: 4Latest Commit: d65b6b5bcd4e89ce1a0eeb74131f98093e85bb3a
