CyberPanel Community
How to remove 8090 port from my domain panel?
St
StevenPhan #1
I follow this guide
However, I do not know how to config the last step for OpenLiteSpeed
I put
REWRITERULE ^(.*)$ HTTP://xxtap/$1 [P]
in rewrite =rule but 502 404 error. Why?
Cy
CyberPanel #2
Which part you don’t understand exactly, as it clearly tells you how and which file you can edit to make it work. For example for OpenLiteSpeed
Open command line and edit: /usr/local/lsws/conf/httpd_config.conf
Paste following content:
extprocessor cyberpanel {
  type                    proxy
  address                 https://switch.cyberpanel.net:8090
  maxConns                100
  pcKeepAliveTimeout      60
  initTimeout             60
  retryTimeout            0
  respBuffer              0
St
StevenPhan #3
Which part you don't understand exactly, as it clearly tells you how and which file you can edit to make it work. For example for OpenLiteSpeed
  type                    proxy
  maxConns                100
  initTimeout             60
  retryTimeout            0
  respBuffer              0
I change switch.cyberpanel.net to my subdomain, is that right?
St
StevenPhan #4
I do not how to Use Rewrite Rules to Proxy to port 8090 exactly, I copied the rule, changed my subdomain in that rule, paste in rewrite rule section, but it still does not work
St
StevenPhan #5
Anyone can help me with this?
er
erselbey #6
First add this to the .htaccess in the file manager of the hostname
vim /home/your.hostname.domain/public_html/.htaccess
RewriteCond %{HTTPS} !=on
RewriteRule ^ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
REWRITERULE ^(.*)$ http://cyberpanel/$1 [P]
###########################################################3
Finally it should be added to the specified file like this;
vim /usr/local/lsws/conf/httpd_config.conf
type proxy
address https://your.hostname.domain:8090
maxConns 100
initTimeout 60
retryTimeout 0
respBuffer 0
Sa
Sapppy #7
Do NOT change the rewrite rule given. It will break the rule.
Fr
Frank #8
Please help,
If use this Rewrite Rules below:
RewriteEngine On
RewriteRule ^/?(.) https://%{SERVER_NAME}/$1 [R,L]
RewriteRule ^(.
)$ HTTP://cyberpanel/$1 [P]
Then i wil get Error page 503
